Using Lock Miter on a long corner
Forum topic by Mainiac Matt posted 01-22-2014 08:38 PM 1988 views 0 times favorited 8 replies Add to Favorites Watch
View Mainiac Matt 's profile
Mainiac Matt
7815 posts in 2264 days
01-22-2014 08:38 PM
Topic tags/keywords: lock miter joint large
When I completed my oldest daughters NYWS hope chest, the side and end panels were connected with a tongue and groove joint, per the plan. But the joint didn’t close tight 100% on one of the corners, and my attempts to fill the tiny, tiny gap with sawdust and glue didn’t pan out.
I’m going to be making a second chest for daughter #2 soon, and am looking for skill builder modifications. So I picked up a lock miter bit, thinking I would solve my corner gap problems and lose the seam line completely.
But now I’m having second thoughts. It seems lock miters are usually used for small boxes, and even drawers, but would a chest edge be too long? and make assembly a challenge?
Here’s a screen shot of the computer model to illustrate the original design and length of the edge.
And this is what I’m thinking about doing….
Is this too long for a lock miter joint?
Has anyone done a corner this long with a lock miter bit?
If so, any assembly tips?
Should I consider ripping at 45 deg. on the TS and then using biscuits to align the panels and add strength?
-- Pine is fine, but Oak's no joke!
8 replies so far
View AlaskaGuy's profile
3988 posts in 2244 days
#1 posted 01-22-2014 10:13 PM
Sure you can. I do 30 inch long one all the time. I’ve done them up to 8 foot long.
Have to go to work now but if you want I could post a picture of the 30’’ and 8 foot long one.
View madts's profile
1854 posts in 2275 days
#2 posted 01-22-2014 10:33 PM
We used to make faux distressed wooden beams this way. 18” long. Just go for it.
-- Thor and Odin are still the greatest of Gods.
View pintodeluxe's profile
5596 posts in 2748 days
#3 posted 01-22-2014 10:34 PM
I have used both locking miters and miters reinforced with biscuits. I like the locking miter better, because the joint really locks together. I recommend leaving the part extra long to cut the locking miter. That way, if you get a little snipe at the router table you can simply trim it off.
Also, making the cut in multiple passes by adjusting the router fence is a great help.
View Gary's profile
9312 posts in 3368 days
#4 posted 01-22-2014 10:39 PM
Matt, I’m with Willie. I use locking miter locks on pie safes and such. Nice joint. Good idea to cut it a little long.
View casual1carpenter's profile
354 posts in 2411 days
#5 posted 01-22-2014 10:53 PM
Matt, I to have used the lock miter on longer pieces and it makes a good joint. The issues which I had were operator error and stupid. As far as the operator error, take your time and dimensioned stock to get the set up right. As for the stupid, let me say that the pieces need a good S4S, I thought that my stock was good enough with sort of S4S before the jointer and planer came along.
View boxcarmarty's profile
15855 posts in 2295 days
#6 posted 01-22-2014 11:16 PM
Matt, I use a lock miter from time to time and have never made a bad joint with it. It gives you a good glue surface and a tight joint whether it is a corner or a panel joint…..
-- My mind is like lighting, one brilliant flash, then its gone.....
Mainiac Matt
#7 posted 01-22-2014 11:44 PM
Thanks for the replies guys.
I’ve discussed it with daughter #2 and we’re going with lock miter corners and raised panels on her Hope Chest.
Nothing like a challenge to motivate me for a project :^)
View basswood's profile
261 posts in 1556 days
#8 posted 01-23-2014 12:13 AM
It will help if you use feather boards holding stock both down tight to the table and to the fence. This will help you get a consistently milled lock miter so it goes together nicely.
