Which Block Plane
« back to Hand Tools forum
Forum topic by missesalot posted 01-21-2014 06:26 PM 1717 views 2 times favorited 16 replies Add to Favorites Watch
View missesalot's profile
missesalot
102 posts in 1470 days
01-21-2014 06:26 PM
Hi,
I’ve posted a few times about starting to set up my woodshop, specifically about some hand tools. I got my hands on a Stanley No 4, looks like from the 20’s, an early Millers Falls smoother, a Stanley no 6, and a Sargent no 7 size jointer. Been playing around with learning to sharpen on water stones, broke down and bought the veritas mark ii. I am thinking, based on my readings here, that I should get a block plane to round out my initial collection of planes for hand work. I am looking at the Lie-Nielsen 102 and 103, one being low angle and one standard. Also looking at the adjustable mouth, thinking this may be most versatile?
Which do you guys find more useful? I know each have a place, but is there one you’d pick over the other if you could only have one?
Thanks in advance
Aaron
http://www.lie-nielsen.com/block-planes/small-block-planes/
http://www.lie-nielsen.com/block-planes/adjustable-mouth-block-planes/
16 replies so far
Smitty_Cabinetshop
14954 posts in 2490 days
#1 posted 01-21-2014 06:41 PM
If just one, it’d be the adjustable mouth #60 1/2 close that LN sells. Beautiful tool, very versatile.
View ksSlim's profile
ksSlim
1264 posts in 2761 days
#2 posted 01-21-2014 07:05 PM
+1 to what Smitty said.
I have several block planes, each is used for a different task.
Bed angle on block can dictate the most probable use.
60 1/2 would make a great first block. Careful, the slope is slippery.
-- Sawdust and shavings are therapeutic
View bandit571's profile
bandit571
18900 posts in 2555 days
#3 posted 01-21-2014 07:05 PM
Maybe find an older Stanley #9-1/2, as well? Same adjustable mouth, too.
Happen to have two of that size in the shop, along with a Stanley #110, and a Stanley #103. ( actually, there are seven little critters sitting around the bench,
Smitty_Cabinetshop
#4 posted 01-21-2014 07:10 PM
Yeah, I can advise within the ‘only one’ constraint above, but like Bandit there are all kinds of block planes in my shop space. :-)
View woodcox's profile
woodcox
1997 posts in 1883 days
#5 posted 01-21-2014 07:18 PM
Maybe consider their rabbeting block plane. I believe the nicker can be retracted or removed when not needed. This plane could pull double duty for several applications, I wish I had one. Of the two you want I would pick adjustable.
-- "My god has more wood than your god" ... G. Carlin.
View TerryDowning's profile
TerryDowning
1074 posts in 1989 days
#6 posted 01-21-2014 07:20 PM
If only 1 then as smitty stated choose a low angle (12 degree bed angle ) with adjustable mouth. By far the most versatile. Here ar some other LA block numbers to look for.
Stanley 60 (Millers Falls 46)
Stanley 60 1/2 New, used, or clone (Millers Falls 56 Low angle there is also a 56 standard angle so be careful here, or 56B)
Stanley 65 (Millers Falls 47)
Stanley 65 1/2 (Millers Falls 57)
-- - Terry
missesalot
#7 posted 01-21-2014 07:20 PM
ok thanks guys, was really hoping that 102 was the pick of the litter:-)
TerryDowning
#8 posted 01-21-2014 07:24 PM
+1 to woodcox suggestion as well
I have the Millers Fall 07 with removable side for rabbeting. It sees regular use. This is similar to the Stanley 140 Be forewarned these are pricey!
My three go to block planes in order of preference
Vintage Stanley 60 1/2
Millers Falls 75
Millers Falls 07
-- - Terry
bandit571
#9 posted 01-21-2014 07:30 PM
I like the 103 better, easier to adjust with a lever. Almost like a 120 style.
Smitty_Cabinetshop
#10 posted 01-21-2014 07:33 PM
The #203 is actually a nice block as well, for none of the reasons indicated above. It just feels right in the hand is seems to adapt well to whatever blocking I ask of it.
View WayneC's profile
WayneC
13751 posts in 3969 days
#11 posted 01-21-2014 08:35 PM
My preference is low-angle block plane with an adjustable mouth. My favorite block plane is a Stanley #65 with a hock replacement cutter. I own the two adjustable mouth LN planes (9 1/2 and 60 1/2) and they are great planes as well. Preference is low-angle block plane with an adjustable mouth.
View Don W's profile
Don W
18560 posts in 2439 days
#12 posted 01-23-2014 01:10 AM
My go to is the #65. Its vintage, a knuckle, low angle, and adjustable mouth. I’m not sure what else besides blue hair you could ask for.
TheWoodenOyster
1311 posts in 1806 days
#13 posted 01-23-2014 05:41 AM
If you are ever going to buy a lie nielsen, this is your chance because it is one of the cheapest things they sell. If you have the funds, go with a lie nielsen. I have the low angle adjustable mouth and it is my go-to for times when nothing else can get it done. It is a stellar plane and performs very well. If you sharpen it, it’ll do almost anything. You could also go with the rabbeting block plane that they sell. It offers a little more versatility and I assume it can still do almost anything the regular low angle block plane can do.
-- The Wood Is Your Oyster
View Loren's profile
9763 posts in 3519 days
#14 posted 01-23-2014 06:13 AM
I would consider Veritas because of the ball tail accessory.
View poopiekat's profile
poopiekat
4322 posts in 3606 days
#15 posted 01-23-2014 06:30 AM
I’m with Bandit on a 9 1/2. If you can find a nice, vintage example, go for it!
