Suggestion to improve "Shops" section
« back to LumberJocks.com Site Feedback forum
Forum topic by Kent posted 01-21-2014 04:12 PM 707 views 0 times favorited 4 replies Add to Favorites Watch
View Kent's profile
Kent
158 posts in 1797 days
01-21-2014 04:12 PM
Now, if you want to view larger pictures of a member’s shop, you just have to click on the thumbnail image and the full-sized image shows up in a new window. This is somewhat functional but not very convenient to navigate because there are no navigation features available with the full-sized image other than what is in your browser. So, if you want to view a full-sized image of another picture of the same shop, you must navigate back, wait for the page to load, and then select the thumbnail that you want enlarged. This is not a show-stopper, but it is rather annoying.
I propose that a better alternative would be to code the images of the Shops section to behave like the images in the Projects section; that is, a user can select a “view images” button below the thumbnails and have them appear in a pop-up that will let them navigate through the entire set of posted picture. You already have the code, so it’s just a matter of including it in the appropriate file. Using the same code will make maintaining the site easier to maintain in the long run, and, as an added bonus, it could marginally reduce your server load and bandwidth requirements because you wouldn’t be repeatedly re-serving the same Shops pages.
-- If I knew then what I know now, I'd have made a completely different set of mistakes.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1728 days
#1 posted 01-21-2014 05:28 PM
”So, if you want to view a full-sized image of another picture of the same shop, you must navigate back, wait for the page to load, and then select the thumbnail that you want enlarged.”
I just hit the next button and the next pic pops right up…
View 7Footer's profile
7Footer
2569 posts in 1949 days
#2 posted 01-21-2014 05:34 PM
Depending on the resolution your monitor is set on you may have to scroll up a little bit to see the next/previous button…. Another alternative if it annoys you that much is to install a plug-in in your browser. I use “searchpreview” and “hoverzoom” in Chrome and just by hovering my mouse over almost any picture it will pop up an enlarged version of it without even clicking on anything.
-- http://www.youtube.com/nrk411
View DrDirt's profile
DrDirt
4424 posts in 3743 days
#3 posted 01-21-2014 05:52 PM
It is cool – - I still wish that the profiles just at least included the State/Province that jocks are in.
It woudl be great to be able to find the “Kentucky” jocks, or the Alaska ones.
Don’t need addresses, but it would be nice to be able to search out “relatively Local” members
View Kent's profile
Kent
#4 posted 01-21-2014 06:38 PM
Kevin & 7Footer:
When I posted this, there were no previous, next and close buttons available; the large images just showed up as just images, not as a web page with an image. That was my point. Magically, they appeared with the navigation buttons about 12 hours ago, which was about 10 hours before this post was approved.
