Spar Urethane on Construction Pine for Outdoor Furniture
Forum topic by paxorion posted 01-20-2014 03:33 PM 1673 views 0 times favorited 6 replies Add to Favorites Watch
View paxorion's profile
1107 posts in 1980 days
01-20-2014 03:33 PM
Topic tags/keywords: pine finishing
LJs – I am thinking of building 2 of these workhorses and was hoping to use construction grade pine (likely 2×12’s ripped). I am looking to leave the finished product outdoors (uncovered) and wanted to know if spar urethane would be sufficient protection for them if recoated every few years, if a different finish would be better, or if I should like for a more weather-resistant non-PT lumber?
-- paxorion
117032 posts in 3511 days
#1 posted 01-20-2014 03:54 PM
Spar varnish should hold up very well.
-- wood crafting & classes
View Lee Barker's profile
Lee Barker
2170 posts in 2785 days
#2 posted 01-20-2014 04:41 PM
Spar urethane, I just learned on LJ, is not the same as spar varnish. If I recall correctly from a recent discussion, spar urethane does not hold up well outside. I hope one of our coatings gurus can weigh in here and correct me if I’m wrong as well as explain exactly what the OP is looking for.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View Manitario's profile
2618 posts in 2817 days
#3 posted 01-20-2014 04:54 PM
I haven’t had very good results from “Helmsman” spar urethane, rarely has the finish survived a year without starting to peel. You may want to use a marine varnish like Epifanes, it will last a lot longer!
#4 posted 01-20-2014 04:56 PM
Lee – I’m hoping to apply some sort of finish that will provide water resistance for the workhorses to be left outdoors year around. I’m in Virginia where we see all the seasons, albeit more mild than elsewhere. I’ll look into the difference between spar urethane, spar varnish, and any other outdoor deck sealer that can be an option.
-- paxorion
View gfadvm's profile
14940 posts in 2624 days
#5 posted 01-21-2014 01:48 AM
The sunlight is what wrecks the Spar urethane. I have had it peel/crack without ever getting wet. The ideal outdoor finish doesn’t exist if you’re looking for maintenance free. My best friend uses some kind of oil on his log home that the log home people recommended and he is happy with it. But he does redo it periodically.
#6 posted 01-21-2014 02:32 AM
Regular maintenance is OK for me. I don’t mind adding to my annual maintenance routine for my deck. I’m mainly concerned with preventing wood rot due to moisture exposure.
-- paxorion
