How do you reverse a right to left router cut?
Forum topic by wastedalf posted 01-20-2014 12:55 AM 1714 views 0 times favorited 20 replies Add to Favorites Watch
View wastedalf's profile
wastedalf
57 posts in 1694 days
01-20-2014 12:55 AM
Topic tags/keywords: safety router
I’ve read a million times… always feed right to left on a router table. So I need some advice. I’m making a bread box, which will have dado joints. The groove is stopped at a certain point, but I don’t know how to do the same groove on the opposite board. A sort-of example picture is below.
I can make the cut that’s on the bottom, but how do I make the cut that’s on the top? The only way my brain works says to feed the piece from the opposite side but I know that’s wrong. How do I tackle this safely? This one task is holding up the whole project.
Thanks in advance.
-- If the iron is blunt, and one does not sharpen the edge, he must use more strength, but wisdom helps one to succeed. - Ecclesiastes 10:10
20 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2000 days
#1 posted 01-20-2014 12:58 AM
It’s a dado. You’re cutting both sides of the groove at one time. R-L or L-R doesn’t matter. Feeding into the cut applies when you’re cutting an edge.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View lateralus819's profile
lateralus819
2241 posts in 1851 days
#2 posted 01-20-2014 01:03 AM
Move the fence?
wastedalf
#3 posted 01-20-2014 01:04 AM
The fence won’t go far enough. The real board I’m doing is 12 inches wide.
lateralus819
#4 posted 01-20-2014 01:12 AM
What i do in a lot of instances, is grab a known straight board for a “guide”. Measure from the outside of the base, to the edge of the bit, and clamp the board, and use it as a reference.
Assuming you can take your router out.
View DIYaholic's profile
DIYaholic
19596 posts in 2637 days
#5 posted 01-20-2014 02:25 AM
JustJoe is JustRight….
17923 posts in 1818 days
#6 posted 01-20-2014 02:36 AM
What Joe said. It doesn’t matter what side you feed from for the dado. The bit is fully in the board so you do not have to worry about the direction the bit is spinning, but it is important to keep the piece tight against the fence. You might want to use a feather board.
View MatthewG's profile
MatthewG
85 posts in 2741 days
#7 posted 01-20-2014 02:43 AM
I think the direction matters—at least it does from my experience. If the fence is to your right—that is the picture you posted—the rotation of the cutter pushes the board into the fence. This works well, helping to hold the piece to the fence. If you feed with the fence to you left, the cutter will pull the piece AWAY from the fence, which is not terrible, but can cause problems if the piece pulls away from the fence.
JustJoe’s reply is true as far as pulling the piece forward—neither direction has a big difference there.
I will often clamp a block to act as a stop, and then lower the piece onto the bit, just so I can keep the fence to the right. That has the advantage of precisely controlling the end of the dado, too.
-- Matthew, from beautiful Wisconsin USA
View Texcaster's profile
Texcaster
1273 posts in 1636 days
#8 posted 01-20-2014 02:46 AM
Right to left feed is always wise, it pulls the job to the fence & is non self feed. You want to make a stop cut. The first thing to do is close up the throat opening. Mark the fence so you know where the cut starts & stops.
Mark the job where you want the cut. Don’t try and start the cut at full depth. Engage the cutter a bit and move forward, lowering the job as you go. Repeat until you can safely get the full depth at the start of the cut.
My router table is crude compared many I see here but it gets the job done. Someday. I do most of my work on my shaper.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Mark Davisson's profile
Mark Davisson
597 posts in 3279 days
#9 posted 01-20-2014 02:47 AM
Gotta use a featherboard for the L to R cut.
-- I'm selfless because it feels so good!
View oldnovice's profile
oldnovice
6752 posts in 3330 days
#10 posted 01-20-2014 06:58 PM
Justjoe is correct!
Use a feather board and stops to make it easier on yourself!
The simple rule for using a handheld router is cutting the inside and outside edges of a picture frame:
Rout the outside counter clockwise.
Rout the inside clockwise.
This rule also applies when cutting an edge with a table mounted router.
This rule does not apply when you are not cutting edges with a handheld or table mounted router.
Texcaster
#11 posted 01-20-2014 08:46 PM
Feed direction does matter, otherwise why would you bother with a featherboard and a stop? I’m guessing you want to avoid a cut like this.
A couple of pencil lines is much less setup, bother and safer. It’s pretty standard.
JustJoe
#12 posted 01-20-2014 09:00 PM
I don’t use a featherboard and I never get cuts like that. I get cuts like this:
I’ve got two hands on the board, only one is pushing it forward, it doesn’t take that much for me to use the other to hold it against the fence – about as much force as it takes to hold a board flat against a jointer fence when I’m running a board through to get a square edge there.
And a stop is used so you know how far to push the board through to get a stopped dado because it’s a bit more accurate than a line drawn on the fence or table, and easier than trying to use calibrated eyeballs to see underneath the board while you’re routing it. :)
View wseand's profile
wseand
2796 posts in 3004 days
#13 posted 01-20-2014 09:10 PM
Take shallow cuts til you get to the depth your looking for, it will be just fine. Do a few practice turns on a piece of scrap if your leery.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1689 days
#14 posted 01-20-2014 09:11 PM
I got to figure out what I’m doing wrong. :O
Texcaster
#15 posted 01-20-2014 09:12 PM
The lines are on the top as well, kind of the whole point.
