Looking for input on Deft clear spray lacquer
Forum topic by dansnow posted 01-19-2014 04:16 AM 2697 views 0 times favorited 13 replies Add to Favorites Watch
View dansnow's profile
dansnow
309 posts in 1838 days
01-19-2014 04:16 AM
Usually I use Lowe’s Valspar clear spray lacquer both gloss and satin for my projects. However I just found that my local store no longer carriers the satin. I have a project almost due for delivery and need to find an alternative. I tested it on a scrap piece and it seems to be okay, just takes a bit longer to dry than the valspar. Urethane doesn’t work well in my unheated shop, so that’s not really an option.
Just wondering what folks think of it.
-- Snow's Wooden Toys & Gifts
13 replies so far
View jumbojack's profile
jumbojack
1676 posts in 2618 days
#1 posted 01-19-2014 04:35 AM
I use it all the time. I prefer the satin over the gloss. You will love the Deft Lacquer.
jumbojack
#2 posted 01-19-2014 04:36 AM
Also, just noticed we are neighbors. Im in Carmichael.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#3 posted 01-19-2014 04:37 AM
+1 What JJ said. All of my projects have been finished with either Gloss or Satin. Check ‘em out if you like.
Mike
View Max's profile
Max
56000 posts in 4267 days
#4 posted 01-19-2014 06:18 AM
Dan, I use the Deft Satin spray lacquer on all of my smaller projects and my frames. I usually use 4 coats and can get it done with about 20 to 30 min. between coats….
View oldnovice's profile
oldnovice
6833 posts in 3362 days
#5 posted 01-19-2014 06:54 AM
+1 Jumbojack, I have used others but Deft is the best I have used!
View Fettler's profile
Fettler
200 posts in 1991 days
#6 posted 01-19-2014 07:29 AM
+1jumbojack, Yep hard to use other finishes in the winter. Rattle can works well.
-- --Rob, Seattle, WA
jumbojack
#7 posted 01-19-2014 09:06 PM
Usually i buy the Deft satin brushing lacquer in the quart can. I spray it from my Critter. It says on the label ‘do not spray’, but I think this is to appease the air quality folks. The Critter is an inexpensive siphon type rig. It does a great job with lacquer.
MT_Stringer
#8 posted 01-19-2014 09:51 PM
What jumbo jack said. I add maybe 10% lacquer thinner and spray away. Been doing it since the 80’s.
Mike
dansnow
#9 posted 01-20-2014 05:44 AM
So far have to say I’m pretty impressed with the stuff. Followed recommendations on the can, 4 light coats, and very pleased with the results.
Thanks for the input folks.
View zazz's profile
zazz
25 posts in 3155 days
#10 posted 01-21-2014 07:16 PM
Go to Ace Hardware they have it in the spray can
ZAZZ
-- BOB ANTHONY
View levan's profile
levan
472 posts in 2973 days
#11 posted 01-21-2014 08:07 PM
You might try Watco. Made by rust-oleum works great for me.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View rrww's profile
rrww
263 posts in 2107 days
#12 posted 01-21-2014 08:23 PM
I use a lot of watco its good.
View keninblaine's profile
keninblaine
130 posts in 1596 days
#13 posted 01-23-2014 01:44 AM
I’m finishing the first project I’ve done in many years, and things have changed a lot over those years in terms of available products. I have been trying to match the finish on my new built-in L-shaped desk to the existing built-in book case in the same room, which is finished in a matte lacquer. When I couldn’t find sprayable matte lacquer anywhere, I went with both Deft and Watco satin aerosols. I couldn’t see much difference between them, and they both went on well. The Deft is more available in my area, at places like True Value Hardware, Home Depot, etc. After a few coats, I decided the satin had too much sheen, so I finally found an aerosol product at Grizzly that is “flat”, so I’ve been putting it on for the final 1 or 2 coats to keep the sheen down a little.
I must say I am impressed with lacquer products (other than the fumes and the need for a good mask and ventilation), including the toner I sprayed (HVLP) on, and the stain after that, followed by the clear coats. I like being able to apply multiple coats of clear lacquer, with light sanding with 600 between coats, ending up with an extremely smooth surface. I have been doing all this during the wettest and coolest time of year here in the PNW, and everything seems to be fine. My garage is unheated except for a space heater I use to try to keep it to around 60 degrees. But I turn it off and ventilate the garage (with cool humid air) when spraying lacquer and for the following couple of hours before turning the heater back on.
-- Ken, Blaine Washington
