Reinstall cabinet door hinge - need help please
Forum topic by Lloyd Davies posted 01-18-2014 08:02 PM 1541 views 0 times favorited 3 replies Add to Favorites Watch
View Lloyd Davies's profile
Lloyd Davies
116 posts in 3295 days
01-18-2014 08:02 PM
Topic tags/keywords: router hinge cabinet repair help door
Does anyone have any ideas on how to rehang my cabinet door. The original hinge has broken through the wood and was about to fall off before I removed it.
And as a second question does anyone know if the original person who installed this should have used an additional screw for extra strength? There’s an extra hole on the hinge that I presume is for an additional screw.
Image 1 – inside wall of cabinet after taking off the door and the hinge
Image 2 – inside wall of cabinet with door off but hinge there
Image 3 – another cabinet door fully installed that is fine
-- Northern California http://www.lloydus.com
3 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3530 days
#1 posted 01-18-2014 08:09 PM
Drill hole out to 3/8 inch diameter, glue wooden dowel rod in hole, cut dowel flush with cabinet surface. Drill pilot hole for hinge screw in dowel as well as new third hole. Reattach hinge.
-- Joe
View Bogeyguy's profile
Bogeyguy
548 posts in 2037 days
#2 posted 01-18-2014 08:18 PM
Lloyd, In my opinion, it looks to me like this door has suffered some abuse. Perhaps some one leaning on top of the door while it was in the open position. The side wall seems to be a particle board/MDF board. A screw will hold fine in this type of board until presssure is constantly applied and then you have what you ended up with. Is there a hole for a third screw in the back under the adjustment plate?? If there is a third screw hole in the hinge base plate there should have been a screw installed, but I don’t think it would have prevented the hinge from pulling away. I really think it was from someone leaning on the door while in the open position.
-- Art, Pittsburgh.
Lloyd Davies
#3 posted 01-18-2014 11:19 PM
@bogeyguy. You are right. 3 year old twins will do that.
@ajosephg. Thanks. I did not think of that.
Thank you both.
