Advice about upcoming project
Forum topic by BenI posted 01-18-2014 06:56 PM 1349 views 0 times favorited 20 replies Add to Favorites Watch
View BenI's profile
BenI
332 posts in 2051 days
01-18-2014 06:56 PM
Hi all,
My pastor recently came to me asking about making a case to hold amps in and I’ve been trying to come up with a design that will work. It will basically just be two sides, top and bottom with some pieces going across to keep it from racking. The main problem is he said that fully loaded it could be 50-60 lbs. so it definitely has to be strong. My initial plan is have the sides join into the top and bottom boards with sliding dovetails but I’ve never used them before so wanted to check and make sure I do it right.
One of my main concerns is that if I have the sides meet the bottom and top how much space should I allow between the end of the bottom board and the dovetail of the side?? (this distance is labeled in the picture) Also will this joint be strong enough by itself to hold that much weight??
I’m afraid that I won’t leave enough room between that space and the outer side of the joint will blow out sooner or later. Brackets are screwed into the front of the sides and them the amps are attached to that.
Thanks in advance for all the help! Just let me know if you need more details.
-- Ben from IL
20 replies so far
View DocSavage45's profile
DocSavage45
8430 posts in 2716 days
#1 posted 01-18-2014 07:22 PM
Dado shelving to add strength. Cut an inset for a back panel. Always keep in mind expansion and contraction of wood in your build. If it must be open use a framing strip on the top and under the first shelf with add strength, give it some nice lines, and reduce wracking from side to side.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3458 days
#2 posted 01-18-2014 07:36 PM
Why are you using sliding dovetails? If you do decide to do this then leave at least 40mm or one and a half inches imho.I would make it using plywood which is strong amplifiers take quite a bit of a beating sometimes when on stage.Alistair ps wait for others to chip in with ideas before making your mind up.
View BenI's profile
BenI
#3 posted 01-18-2014 07:59 PM
Doc – there actually isn’t any need for any shelves because they can be ‘stacked’ when attached to the mounting brackets but I was planning on putting the back part in a rabbet along the back.
Scotsman – Mainly using sliding dovetails to try something new and for strength, don’t want it coming apart. I believe they’re for pre-amps, I’m not a musician so no idea what that means but that they’ll be a couple of them in it at once.
-- Ben from IL
View hobby1's profile
hobby1
335 posts in 2171 days
#4 posted 01-18-2014 08:01 PM
dovetail joint like that will break easiily in that kind of hefty situation, the dovetail is good for sides assembly but not for bottom assembly with that much weight.
View wseand's profile
wseand
2796 posts in 2915 days
#5 posted 01-18-2014 08:06 PM
I wouldn’t use sliding dovetail. I would use something like my crude drawing. It will add a lot more gluing surface and stability. I would also add some sort of face frame to tie them all together. as well I would add some sort of back onto it even if it’s not completely covering the back something to hold it all together
View BenI's profile
BenI
#6 posted 01-18-2014 08:49 PM
Thanks for all the quick replies!
Hobby- The weight of the amps will be on the sides because of how the brackets attach but it does make sense.
wseand – I was planning on using solid wood so I wouldn’t have to do any edge banding or bother with a face frame but I have thought about corner bracing to make it a little more sturdy. In your drawing the top (and bottom) would fit into a groove in the sides, correct?
Hopefully this question isn’t as stupid as I might think it is…
The grain should go ‘around’ the case not front to back right??
-- Ben from IL
DocSavage45
#7 posted 01-18-2014 08:54 PM
No stupid questions! Always horizontal grain patters, Matching if possible. KISS! I have to remember this….LOL
View BenI's profile
BenI
#8 posted 01-18-2014 09:05 PM
Haha thanks for understanding Doc. I thought so since the strength is along its grain but wanted to check.
-- Ben from IL
View levan's profile
levan
472 posts in 2853 days
#9 posted 01-18-2014 09:07 PM
How large is this to be. Can you put a back on it.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View BenI's profile
BenI
#10 posted 01-18-2014 10:49 PM
I don’t know the exact dimensions yet (should find out tomorrow) but roughly 12” in each dimension give or take a few. However, I need to allow access in the back for wires and the fans so I can’t have the whole back cover back I will have some of it covered.
-- Ben from IL
View BenI's profile
BenI
#11 posted 01-18-2014 11:42 PM
Can anyone chime in on what wseand picture was showing as to whether the top and bottom would fit into the sides or the sides would fit into the top and bottom??
I’ve been trying to see which way he meant to have the design and it seems like either way could work.
-- Ben from IL
View Clint Searl's profile
Clint Searl
1533 posts in 2234 days
#12 posted 01-19-2014 12:13 AM
Dovetails ain’t smart. What’s wrong with screws and glue?
404 - Not Found
2544 posts in 2842 days
#13 posted 01-19-2014 12:51 AM
Make it from veneered ply with pocket screws and glue. Very strong for this type of application.
DocSavage45
#14 posted 01-19-2014 02:37 AM
Not sure of the vision here. Or the materials?
Do you have a concept in mind? Corner braces are good for rigidity. Using edging can be decorative and functional. Fans for cooling the amps?
If you use a shelf with a dado then the downward weight would also add strength and rigidity.
Looks like a sliding dovetail is overkill here?
Good luck. Make a scale model for concept and practice.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1601 days
#15 posted 01-19-2014 02:46 AM
