Painting a dowel?
Forum topic by byerbyer posted 01-17-2014 05:37 PM 3668 views 0 times favorited 4 replies Add to Favorites Watch
View byerbyer's profile
241 posts in 1908 days
01-17-2014 05:37 PM
Topic tags/keywords: question modern finishing painting poplar dowel
I’m in the middle of building a “modern” style crib that will have white painted dowels between natural finished walnut. Do any LJ’s have slick trick for painting a round dowel? I tried making some braces I could lay them flat and then roll the paint on with a little roller, but there isn’t enough surface area for the roller to actually roll. I also tried just a foam brush, which was a step in the right direction and will suffice for priming, but not the final coat.
I’m thinking a short screw in the end and hang it from a piece of string or stand them on end in a block…
Any suggestions would be great!
-- Byer-- "Comparison is the thief of joy" -- T.R. Roosevelt
View HerbC's profile
1727 posts in 2794 days
#1 posted 01-17-2014 11:56 PM
Hang them and use spray paint.
I’d recommend a spray laquer.
-- Herb, Florida - Here's why I close most messages with "Be Careful!"
View Grandpa's profile
3259 posts in 2610 days
#2 posted 01-18-2014 04:39 AM
Screw in both ends so you can control the swing. If you want to lay them down, a screw in each end and a board under the screws. Turn it by hand and lay it down when you are finished.
View Jetboater's profile
3 posts in 1523 days
#3 posted 01-19-2014 07:39 PM
One neat way is to spin the dowel as you paint it. Keep it spinning while it dries to eliminate any runs or imperfections. That’s the hardest part – avoiding runs and marks from holding the dowel. The guys who make custom wooden archery arrows have been doing it that way for a couple hundred years.
Check out this video. The video show striping (cresting), but you can paint the whole dowel if you want. You can rig up something pretty easy, or buy a cheap commercial arrow crester. If you have access to a lathe, you’re already there. Custom fishing rod makers use the same basic technique.
View kaerlighedsbamsen's profile
1244 posts in 1648 days
#4 posted 01-19-2014 07:53 PM
Hang them and use a “painting pillow” to paint them in one go. Not sure about the name in english. It is like a pieze of carpeting with small brushes on one side. Really quick and gives a nice, even finish
-- "Do or Do not. There is no try." - Yoda
