Table Saw Sled Question
Forum topic by Steve Kreins posted 01-17-2014 04:41 PM 6103 views 0 times favorited 17 replies Add to Favorites Watch
View Steve Kreins's profile
Steve Kreins
358 posts in 1595 days
01-17-2014 04:41 PM
Topic tags/keywords: question tablesaw sled runners craftsman
Wood Whisperer has a great instruction video on making a table saw sled at http://www.youtube.com/watch?v=uE9f4bp_wm8
The question I have is my Craftsman Table Saw doesn’t have straight edges on the miter slots, so any ideas how I make the runners? Do I make my square stock runners and simply rabbit the top edges?
Notice the slot tabs that they use to hold the miter slide down.
-- I thank God for everything, especially all of you!
17 replies so far
View crank49's profile
crank49
4030 posts in 2936 days
#1 posted 01-17-2014 05:40 PM
Those “tabs” are one of the first things to avoid when shopping for a table saw.
But, now that you have them the next best thing to do is grind them off.
Many top end cabinet saws seem to manage just fine without any method to retain the miter gauge in the miter slot.
Note, however that your slot is possibly not standard size either, so you still won’t be able to use accessories like Incra miter gauges, tenon fixtures and such. But that depends on the saw model. A standard miter slot is 3/8” deep and 3/4” wide and many accessories are designed to fit these slots.
View anile8tor's profile
anile8tor
15 posts in 1715 days
#2 posted 01-17-2014 05:44 PM
I had this same issue with my Craftsman table saw. I cant wait to get a larger shop so I can get a better saw, but this saw works for the time being. i ground off the tabs and made the slots standard shape as opposed to the “t” track shape. It ony took a few minutes and I have nto missed them since.
-- anile8tor
Steve Kreins
#3 posted 01-17-2014 05:57 PM
Gee guys, why didn’t you tell me this stuff before I bought it? ;)
It’s what I could afford and I will make it work! Even if I have to go to your houses and steal your tools.
View Picken5's profile
Picken5
250 posts in 2657 days
#4 posted 01-17-2014 06:43 PM
Steve—I used to have a TS with slots like that and I didn’t grind them off. (I feel your pain BTW.) What I did was to make my own runners by ripping some hardwood strips to the width and depth of the miter slots. Then, I used a router to cut rabbet along both edges of each strip to create a space for the “tabs”. If you’re careful, you can create a tighter fit than what you’re getting with your current miter gauge. The cross section of the new runner should be pretty much the same as the one on your miter gauge. If you apply some paste wax to the runners and to the inside of your TS slots, they’ll slide easier.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
Picken5
#5 posted 01-17-2014 06:50 PM
Another thing with those type miter slots—as Michael said, the slots may not be 3/4” wide—which is the de-facto standard for such things. When I was looking into feather boards I was deciding between making some versus buying them. And I found there are not too many choices for buying TS accessories for non-standard slots. But Milescraft made a few items that worked out OK—and not terribly expensive. (Yeah, they were plastic—but, as I said, they worked out OK.)
View Goodsh's profile
Goodsh
79 posts in 1885 days
#6 posted 01-17-2014 07:46 PM
Judging from the picture I have the same crappy saw. It’s annoying for many reasons and has a lot of faults but I make it work. I’m definitely learning what I REALLY want in a table saw. The slots are not standard 3/4. I think it’s more like 5/8 but I can’t remember. There’s a few threads on this issue. For an alternative solution:
http://lumberjocks.com/projects/26395
I used an angle grinder and removed the tabs and it’s much better now. Before I did that planed a piece of oak to the thickness of the mitre slot and then cut dadoes (just a saw kerf) in both faces of the board just up from the edge of the board (I forget the distance now but it was the distance of the bottom of the mitre slot to the stupid tabs – maybe 1/4”). The dadoes should be as deep as the distance that the tabs stick out. Then I moved the fence over a blade width and ripped a 3/8” piece that ran along the dado line. You end up with a “T” shaped runner fits slides freely through the mitre slot and tabs. Worked great.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2778 days
#7 posted 01-17-2014 07:51 PM
Just mill hardwood strips to fit. I have made jigs and runners for that saw in the past. It works okay, but won’t fit other standard miter slot accessories. I sold the saw because the arbor nut wasn’t long enough for a full dado set.
View ScottStewart's profile
ScottStewart
119 posts in 2097 days
#8 posted 01-17-2014 08:04 PM
I used to have a Craftsman table saw with the same problem and liek Pintodeluxe, I milled wood for runners. (if you cut the edge off a plainsawn oak board and rotate, you get quartersawn runners for stability).
Mark’s information is good, and the information on how to square and attach the fence is great. The one thing I changed when I upgraded my TS was to make the fence out of a laminate of plywood and MDF (There is a FWW video on making the fence, but I think it’s behind the paywall.) This is my 3rd sled, and it’s the first one that the fence has stayed exactly 90 degrees to the blade. I bought lexan to make a guard, but haven’t assembled it yet.
Good luck, it looks challenging, but it will be worth it once you get it set up nicely.
Steve Kreins
#9 posted 01-18-2014 02:38 PM
OK, I’m going to solve this problem. I am going to get a branch off my oak tree out back, get out my pocket knife and start whittlin.
View retfr8flyr's profile
retfr8flyr
384 posts in 1634 days
#10 posted 01-18-2014 05:01 PM
For those of you with non standard slots, these will fix your problem. http://www.microjig.com/products/zeroplay-guide-bar/
-- Earl
Steve Kreins
#11 posted 01-18-2014 07:19 PM
They look great and they are only $35 for a pair with stops.
I just sent them an e-mail asking if they will work with the Craftsman Tabbed slots. If they say yes I’ll order them and let everyone know how they work.
Thanks Earl
crank49
#12 posted 01-18-2014 07:59 PM
They should work if they start out narrow enough for your slots. You will still have to remove the tabs, however.
crank49
#13 posted 01-18-2014 08:01 PM
I think if I had those tabs in my slots I might try getting some HDPE (cutting board material) and milling some runners to fit the slot. Then, if that didn’t work I grind those suckers off.
Goodsh
#14 posted 01-19-2014 02:09 AM
According to their website it’s for standard (3/4”) slots mitre slots so I’m not sure it will work. The saw I have is the Craftsman 10” Table Saw with Laser Trac® (21807) and from your picture it looks the same. The mitre slot on mine is 5/8”. If yours is the same as mine I think the choices are either to mill a board to 5/8”, cut a runner, and find a way to put rabbets in it (either as I did or as Picken 5 described) so the runner fits tight in the bottom of the slot but will slide freely past the tabs that jut out into the slot or remove the tabs.
It’s unfortunately not as easy as just milling a runner to fit the width of the slot with those tabs jutting out and blocking the way. I suggest removing them. It took me five minutes and I’m so glad I took them off. They’re pointless and once removed all you have to do is mill a 5/8” board and rip 3/8” runners and you’re good.
Steve Kreins
#15 posted 01-19-2014 01:47 PM
Several of you have talked about grinding the tabs off. How and I’m I likely to cause further problems?
