Any thoughts on table-mounted router noise control?
Forum topic by HarveyDunn posted 01-17-2014 02:45 PM 1763 views 0 times favorited 48 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1783 days
01-17-2014 02:45 PM
Topic tags/keywords: question
I’m buying my first router table. My workspace shares one wall with one neighbor and I have another neighbor above me (I’m on the ground floor). My floor is poured concrete; the walls are whatever you call modern metal frame with drywall over it construction.
I want to be a considerate neighbor and so I’m interested in mitigating the amount of noise that travels to those adjacent units.
I haven’t bought a router yet, so lets start there. Is there any significant difference among models in terms of noise? One of the models that is directly compatible with the router lift I’m buying is the Hitachi M12VC. The manufacturer says it has “class leading noise level, only 79.5dB for a quieter workshop”. Purdue University has a noise comparison chart – it says a garbage disposal is 80dB.
Then there is the table. I’m buying the Incra unit, which is just an open stand.
I will enclose it by sliding in 1/2” panels.
And I’m also getting the Clean Sweep downdraft dust collection box.
Would the material I choose for those panels impact the noise?
Should I isolated it from the cement floor with a rubber pad, or would that not have any effect?
Any other thoughts?
48 replies so far
View dbray45's profile
dbray45
3320 posts in 2829 days
#1 posted 01-17-2014 03:02 PM
This is what I use for hearing protection – Peltor Optime 105:
Router – get 3+ HP
-- David in Damascus, MD
HarveyDunn
#2 posted 01-17-2014 03:04 PM
Thank you, but what I am concerned about is noise transmission that might annoy my neighbors.
dbray45
#3 posted 01-17-2014 03:12 PM
I built this. I enclosed the router motor. There is a 4” port on the left, a 4” veined vent on the right and a 2” on the top. Still noisy but better.
HarveyDunn
#4 posted 01-17-2014 03:17 PM
Wow – that’s a beauty! I’d like a bathroom vanity that looks like that!
5013 posts in 2545 days
#5 posted 01-17-2014 03:24 PM
The enclosure will help (get the bottom as well), as will that dust thingy. But they are loud, and I suspect since you have a dust box around they’ll be something else running. So it may be beyond what you want. Nature of the beast. The universal motors are loud enough on their own, but add in a cutter that’s spinning really fast and some sort of vac/DC, you’ll find it a lot louder than a garbage disposal.
dbray45
#6 posted 01-17-2014 03:26 PM
THe top was from Rockler. If you want to learn how to build it, get the cheapest plywood you can get, some fairly straight 2×4s, a box of deck screws and get to work – add stain and poly to finish.
This is all cheap plywood, I keep it because it works and it reminds me that our shop cabinets are great places to learn how to build this stuff – make your mistakes here – not where others see it.
dbray45
#7 posted 01-17-2014 03:29 PM
This is what the customers see (a bathroom cabinet) -
HarveyDunn
#8 posted 01-17-2014 03:29 PM
That’s a good point, Fred…there will be a dust collector, which is another 80dB.
David, I think you’ve got good taste and nice sense of proportion. I’m going to follow your advice. How did you attach the router top to the cabinet.
View PurpLev's profile
PurpLev
8539 posts in 3701 days
#9 posted 01-17-2014 03:29 PM
lets face it – the noise from woodworking machines (especially universal motor machines) WILL annoy neighbors :)
dbray45
#10 posted 01-17-2014 03:31 PM
Figure 8s from Rockler.
I am the neighbor from hell – my shop is in the basement – in a townhouse :-)
View TheDane's profile
TheDane
5460 posts in 3715 days
#11 posted 01-17-2014 03:51 PM
I have a Bench Dog router table with a PC690 motor in it … noise isn’t bad … until the bit hits the wood.
There may be quiet routers, but I have never seen (or heard) them.
View Loren's profile
10476 posts in 3700 days
#12 posted 01-17-2014 04:01 PM
Routers are less noisy at slower speeds. On my variable
speed routers I usually run them slower than top speed
because 1) I’d rather route accurately than route fast
most of the time and 2) they’re not as loud.
HarveyDunn
#13 posted 01-17-2014 04:08 PM
Is the speed needed connected to the HP of the unit? For example, could a 3HP router route a board well at a lower speed whereas a 2HP router would need a higher speed for that same board?
dbray45
#14 posted 01-17-2014 04:24 PM
If you are doing panels, 3+ HP is the way to go. Had a 2HP router and burned it fairly quickly.
#15 posted 01-17-2014 04:27 PM
You can feed the work faster at higher speeds generally.
With larger bits like panel raisers it is a good idea to run
the router slower because if you don’t the rim speed
gets really fast and may cause burning or other issues.
showing 1 through 15 of 48 replies
