Does a small (tiny) shop need a cyclone?
Forum topic by HarveyDunn posted 01-17-2014 01:19 AM 1101 views 0 times favorited 11 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1697 days
01-17-2014 01:19 AM
Topic tags/keywords: question
I’m setting up a very small shop. Bandsaw, router table and maybe a thickness planer. Everything else hand tools.
Each machine will be used one a time. And there is no option to roll them outside and use them in the open air.
I want to keep it as clean as humanly possible and of course want to look after my lungs.
I’m more than a little confused by dust collection technology. I understand that you need two things. One, a power plant – the thing that does the sucking, either a shop vac or a dust collector. Two, a sperator which sits between the tool and the power plant and collects the big chunks before they get to the power plant. Furthermore, I understand that the power plant should have a HEPA filter.
Is that all correct?
Given that I am serious about lung protection, do I have to buy a cyclone – is that the only way to enable the HEPA filter to do its job, namely, very fine particulate collection? Or is there a smaller less expensive option that will work for such a small shop?
11 replies so far
View Loren's profile
10262 posts in 3614 days
#1 posted 01-17-2014 01:35 AM
You can get a regular dust collector and get a pleated
filter for it, putting a plastic bag or trash can on the
bottom. There are also felted bags that filter down
to smaller particle sizes.
http://www.highlandwoodworking.com/shakerfeltpolyestermicronfilterbag20x32.aspx
HarveyDunn
#2 posted 01-17-2014 01:37 AM
Can you show me what you mean by “a regular dust collector”?
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#3 posted 01-17-2014 01:37 AM
In a small shop the dust will be even worse, same dust, smaller space. The planer will make the most, the others generate a lot of dust too. If you live in a warm climate you could blow it out a window. If you heat your shop that probably won’t be an option. The best option is collect dust at it’s source with some sort of collector or a shop vac and then install an ambient air cleaner to get the fine dust that the collector misses.
-- Bondo Gaposis
HarveyDunn
#4 posted 01-17-2014 01:39 AM
Doesn’t collecting dust at the source with a shop vac just blow the very fine particulates higher in the air? Can I collect them at the source rather than hoping to collect them later.
For the record: blowing out the window is not an option, there is no outdoor option of any sort in my scenario.
#5 posted 01-17-2014 01:46 AM
This sort of thing:
http://www.harborfreight.com/garage-shop/stationary-dust-collectors/2-hp-industrial-5-micron-dust-collector-97869.html
I guess they are “single bag” though they have two. Something in
the 700 CFM range will run on 110v power and be adequate for
your needs.
Penn State has effective dust collectors in a lot of configurations
for hobby shops.
http://www.pennstateind.com/store/bag-style-dust-collectors.html
As always, second hand machinery is a way to get more bang for your buck.
View Jokker78's profile
Jokker78
136 posts in 1663 days
#6 posted 01-17-2014 02:34 AM
I use a dust depety hooked to my shopvac .for it does a good job for me and saves the filter of my shopvac
-- Measure once, cut , measure again, cut and damn its still to short
HarveyDunn
#7 posted 01-17-2014 02:35 AM
How many CFM should I be looking for? It will be used with a bandsaw or a router table that has two dust ports – one on the fence and one below the table.
Jokker78
#8 posted 01-17-2014 02:41 AM
Mine is just the cheap 16gallon one, not sure of the cfm. I use a hepa filter in the shop vac. I use it with my router (dust collection on the bottom). And my planer and table saw. I hook if to what I need to use.
View lndfilwiz's profile
lndfilwiz
103 posts in 1566 days
#9 posted 01-20-2014 03:51 PM
I love my Dust Deputy. It has greatly improved the air quality in my shop. I has extended the life of the shop vac filter. I have a large Craftsman shop vac and the filter are expensive. I would go through 2 a year. Now I have the DD I have gone over 2 years and the shop vac filter is still good. Just my 2ยข worth.
-- Smile, it makes people wander what you are up to.
View bbc557ci's profile
bbc557ci
595 posts in 2040 days
#10 posted 01-20-2014 04:09 PM
You don’t necessarily need a cyclone, but you should have a good dust collection and air cleaning system. I would say more so in a small/tiny shop than in a large shop.
-- Bill, central NY...no where near the "big apple"
View Bobsboxes's profile
Bobsboxes
1362 posts in 2630 days
#11 posted 01-20-2014 04:17 PM
I have a couple of big Craftman shop vacs with Dust Deputies hooked to them. Google Dust Deputy and have look.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
