Old T-Shirts for Applying Finish??
Forum topic by Matt in Franklin posted 01-16-2014 09:32 PM 1046 views 0 times favorited 11 replies Add to Favorites Watch
View Matt in Franklin's profile
Matt in Franklin
294 posts in 1576 days
01-16-2014 09:32 PM
Hi all,
Would you advise the use of my old t-shirts (think Hanes/FoTL) as wiping rags for applying stains/oils/varnishes? Or would these be more suitable as cleanup rags?
-- Follow me on instagram and facebook @mwawoodworks , http://instagram.com/mwawoodworks/, https://www.facebook.com/MWAWoodworks
11 replies so far
View bondogaposis's profile
bondogaposis
4682 posts in 2315 days
#1 posted 01-16-2014 09:34 PM
Yep, they’re very good for that use.
-- Bondo Gaposis
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#2 posted 01-16-2014 09:35 PM
That will work fine for applying stains. I either use lint free washrags, or spray on stain. Both methods work fine, although spraying is quicker on large or complex projects.
View TheDane's profile
TheDane
5399 posts in 3626 days
#3 posted 01-16-2014 09:36 PM
Yup … I cut them into squares (about 8” x 8”) and use them to apply Danish Oil and wipe-on varnishes/poly.
Just make sure they are clean.
View Monte Pittman's profile
Monte Pittman
28907 posts in 2302 days
#4 posted 01-16-2014 09:39 PM
Should work fine. Some of the store bought rags you get are cut up Tshirts.
-- Mother Nature created it, I just assemble it.
View Marcus's profile
Marcus
1163 posts in 1983 days
#5 posted 01-17-2014 01:44 AM
I almost exclusively use t-shirts for finishing. I have a ton of undershirts from work that get some pretty nasty pit stains on them, so I cut the non nasty parts out and used them in the shop. Work great.
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#6 posted 01-17-2014 01:59 AM
I buy those boxes of cut up T shirts at HD to apply stain and shellac. Works great.
I WEAR my old T shirts until my wife throws them out!
View jerrells's profile
jerrells
918 posts in 2848 days
#7 posted 01-17-2014 01:14 PM
YEP they work great at this workshop
-- Just learning the craft my Lord and Savior Jesus Christ practiced.
View gtbuzz's profile
gtbuzz
427 posts in 2405 days
#8 posted 01-17-2014 01:34 PM
They’ll work fine for that. One thing I’ll recommend is after you cut them up, run them through the wash a few times so that any loose fibers on the edges get broken away in the washing machine or dryer.
View Danpaddles's profile
Danpaddles
573 posts in 2275 days
#9 posted 01-17-2014 02:12 PM
I think the ones you’ve worn for 4 years are better then the boxed rags at the BORG. Less lint on the shirts you’ve washed 50 times.
Don’t know of any better rags for woodworking.
-- Dan V. in Indy
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1691 days
#10 posted 01-17-2014 02:23 PM
I only use white ones.
Matt in Franklin
#11 posted 01-17-2014 07:49 PM
I cut up about 30 of my old white T-shirts last night. I had been saving them for a couple three years or so to use as general cleaning rags for paint or grease, but I think now I have a better use for them.
