Is this red oak?
Forum topic by bigblockyeti posted 01-16-2014 03:16 PM 1403 views 0 times favorited 32 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5111 posts in 1714 days
01-16-2014 03:16 PM
This tree was cut about a month ago, I ripped a couple logs into planks last night < 12hr. ago. The board on the outside of the stack seems to have dried quite a bit more than the one pictured that was within the pile. The moisture content registered at about 40% immediately after being cut, which has given it a much darker look, nothing like what I’m used to seeing red oak looking like. So is it red oak or something else?
32 replies so far
View knotscott's profile
knotscott
8006 posts in 3369 days
#1 posted 01-16-2014 03:37 PM
No. The middle pics look like black walnut to me.
bigblockyeti
#2 posted 01-16-2014 03:42 PM
I hope you’re right, I already have quite a bit of red oak drying, not so much walnut. BTW the moisture content is still quite high in the two middle pictures, don’t know how much lighter it will be as it dries completely.
View ddockstader's profile
ddockstader
155 posts in 3255 days
#3 posted 01-16-2014 05:43 PM
I’ve got quite a bit of walnut and have air dried some myself. That doesn’t look like walnut to me. It looks more like Siberian elm or maybe hickory. Really doesn’t look like walnut
bigblockyeti
#4 posted 01-16-2014 05:50 PM
I know that it was cut from a yard here in north east Ohio, so it’s certainly not anything too exotic, hickory perhaps. The problem is the tree was de-limbed and down to just the trunk (3’ – 4’ diameter) when I got there, so I have no shape to reference and the leaves I’m sure have been gone for a while. Just wish there was an easier way to identify wood by the bark, grain and where it’s from without any other tell tale signs.
View DaddyZ's profile
DaddyZ
2475 posts in 3034 days
#5 posted 01-16-2014 06:01 PM
http://www.hobbithouseinc.com/personal/woodpics/elm,%20american.htm
I think American Elm
DaddyZ
#6 posted 01-16-2014 06:19 PM
http://www.hobbithouseinc.com/personal/woodpics/oak,%20red.htm
Of course it could be red Oak as you are thinking
View dhazelton's profile
dhazelton
2766 posts in 2290 days
#7 posted 01-16-2014 06:25 PM
What did the leaves look like? Sawtooth like the picture DaddyZ posted means elm.
bigblockyeti
#8 posted 01-16-2014 06:43 PM
The leave were long gone as it was cut mid-December here in northern Ohio. If I could have seen any of them, it would have allowed me to positively identify the wood.
View Quanter50's profile
Quanter50
278 posts in 2290 days
#9 posted 01-16-2014 08:14 PM
Does’nt look like any red oak I’ve seen before. Maybe black locust?
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#10 posted 01-16-2014 08:19 PM
It is pretty hard to tell when the grain is that gnarly, but one way to tell is to mill some of it. You will know in a hurry if it is black oak / pin oak / swamp oak. It smells like lightning hit the outhouse.
dhazelton
#11 posted 01-16-2014 08:56 PM
You could also just take a splitting maul and blow through a short piece. If it’s elm it will splinter and rip apart as opposed to a clean split.
bigblockyeti
#12 posted 01-16-2014 09:04 PM
Pinto, I suspect it’s not any of the oaks you mentioned, as the smell was actually quite pleasant, almost rose like. I have cut up part of a pin oak before and it definitely smelled nothing like this does.
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#13 posted 01-16-2014 09:49 PM
Tough to identify young trees especially by their bark.
View basswood's profile
basswood
261 posts in 1614 days
#14 posted 01-16-2014 09:57 PM
Looks like Locust bark to me too… no way I would put money on it though.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
bigblockyeti
#15 posted 01-16-2014 10:12 PM
Since I do know exactly where the tree came from, maybe I’ll take a ride over there once the trees leaf out up here and see what species the adjacent trees are. I know I’ll be making a bit of an assumption, but if I remember correctly everything did look to be the same species around what was left of this tree when I got there. I’m not in a big rush as this stuff will surely take quite a while to air dry down to a moisture content where I can actually use it.
showing 1 through 15 of 32 replies
