swing and spindle size spindle
« back to Woodturning forum
Forum topic by Nubsnstubs posted 01-16-2014 01:31 PM 840 views 0 times favorited 6 replies Add to Favorites Watch
View Nubsnstubs's profile
Nubsnstubs
1280 posts in 1696 days
01-16-2014 01:31 PM
I have a question for the machine guru’s. At what swing does a 1” spindle become too wimpy to handle a larger piece? I’m asking because I have an extra headstock from a 46-450 lathe and would like to build it up to at least a 16” swing…. Would the 1” spindle handle it?............ Jerry (in Tucson)
View Wildwood's profile
Wildwood
2300 posts in 2101 days
#1 posted 01-16-2014 02:18 PM
Guess many of today’s message board guru’s would say no!
Remember folks adding riser blocks to headstock on their old spindle lathes that came with 1” x 8 TPI spindles.
Guess depends upon whether modifying tool rest base & tailstock worth the effort. Only question would have,” will bearings installed in 46-450 headstock handle the job?”
-- Bill
Nubsnstubs
#2 posted 01-16-2014 02:36 PM
The bearings will be changed to tapered roller bearings when the time comes at a cost of about 10 bucks each. The tailstock and tool rests will also be changed to fit. I have a welder friend that lets me use his mill and lathe at no charge, plus he let’s me rummage through his waste metal for what ever I need at no charge. Gasoline getting to and from his shop is my only expense. Since I’m retired, my time is not worth anything, so I’m ahead…....... Jerry (in Tucson)
Wildwood
#3 posted 01-16-2014 08:39 PM
Jerry sounds like a plan go for it!
-- Bill
View JamesVavra's profile
JamesVavra
304 posts in 3282 days
#4 posted 01-17-2014 03:03 AM
I don’t see why not. My Jet 1442 has a 1” spindle and 14” swing and has no problem with large, out of balance blanks. 16” is where most manufacturers step up to 1.25” spindles, but I think that you can still get away with 1” at that size.
View REO's profile
REO
928 posts in 2040 days
#5 posted 01-17-2014 12:15 PM
The diameter doesn’t make nearly as much difference as the length of the piece
Nubsnstubs
#6 posted 01-17-2014 01:54 PM
Thanks for the replies, Guys…. My goal is to turn larger off center stuff, like wall hangings rather than larger and deeper. A 12” swing limits any natural shaped item to about 9” wide, and that’s the reason for wanting to upgrade the swing…. Tonight I’ll post a picture of what I’m doing so you’ll get a better idea of what my goal is. ..........Jerry (in Tucson)
