Thien Dust Collector mod - Why??
Forum topic by becikeja posted 01-16-2014 12:44 PM 1452 views 0 times favorited 9 replies Add to Favorites Watch
View becikeja's profile
becikeja
841 posts in 2719 days
01-16-2014 12:44 PM
All over LJ and other sites as well I have seen dust collectors modified with the Thien separator. I am very curious and have an itch to go add one of these to my system but I don’t know why.
I get the fact that the larger particles fall into this new added trash can and it reduces the amount of waste that ends up in the bag. That appears to be a significant advantage because its easier to dump.
But it seems to me that adding this additional component would reduce the amount of suction available at the end of the hose. The trade off’s between suction loss and ease of waste disposal don’t seem to offset for me.
What am I missing? Are there advantages that I am not taking into consideration.
9 replies so far
View gtbuzz's profile
gtbuzz
427 posts in 2348 days
#1 posted 01-16-2014 01:21 PM
You’re right, it does slightly reduce the suction due to the increase in static pressure. The main purpose of these things, however, is not to keep the bag from filling up as quickly but rather to keep far less material out of the filter. In doing so, it remains free and clear for longer. You end up taking the initial hit on suction but over time, it remains relatively consistent, whereas if you didn’t separate out the bulk of the heavy particulates first, they would really degrade performance over time.
View bondogaposis's profile
bondogaposis
4608 posts in 2257 days
#2 posted 01-16-2014 01:33 PM
Yes, gtbuzz has it right. Another advantage is that it keeps the majority of the debris from ever contacting the impellers. That reduces wear and tear and on the dust collector especially when you consider how likely it is to suck up screws and other harsh bits that can be found on most shop floors.
-- Bondo Gaposis
4881 posts in 2399 days
#3 posted 01-16-2014 01:36 PM
Plus, it’s easier to empty the can with a Thein than a dust bag on a SS DC.
View DIYaholic's profile
DIYaholic
19538 posts in 2581 days
#4 posted 01-16-2014 02:46 PM
A canister filter improves air flow (due to the increased surface area) and removes more of the dangerous fine particles (better for your lungs). I highly recommend a Wynn Nano filter. If you add a Thien pre-separator and also upgrade to a canister filter, the loss of suction (from the Thien upgrade) is offset by the increase of suction provided by the canister. You also will be able to reduce the risk to your lungs!!!
becikeja
#5 posted 01-17-2014 11:33 AM
good points to consider.
Thanks
View bbc557ci's profile
bbc557ci
595 posts in 1980 days
#6 posted 01-17-2014 02:26 PM
Loss of suction …. My HF DC is integrated with a cyclone and it flattened a Brute 30-32 gallon can, so I had to switch to a metal can. No expert here at all, but think I can live with the minor loss of suction ;o)
-- Bill, central NY...no where near the "big apple"
View BTimmons's profile
BTimmons
2303 posts in 2391 days
#7 posted 01-17-2014 03:58 PM
Bill, I did the exact same thing when I made my first separator for the HF DC. Plastic trash can crumpled like a paper bag!
-- Brian Timmons - http://www.BigTWoodworks.com
9961 posts in 3554 days
#8 posted 01-17-2014 04:10 PM
I have a cyclone and the filter gets clogged often. A larger
filter would be one solution. Mine is a diesel truck filter.
I’d prefer outside bags. I have a second dust collector
with bags and it doesn’t lose suction the way the cyclone
does. To be fair the cyclone is underpowered and
the bag collector is a beast.
View Mark's profile
Mark
878 posts in 1881 days
#9 posted 01-17-2014 04:26 PM
becikeja. I’m running a Thien clone on a 5gal plastic paint can with a 14 gal. Rigid Shop vac. Works like a hot damn.
-- Mark
