Tablesaw Belt
Forum topic by Woodworker101 posted 01-16-2014 12:39 AM 668 views 0 times favorited 1 reply Add to Favorites Watch
View Woodworker101's profile
Woodworker101
22 posts in 2106 days
01-16-2014 12:39 AM
Hi LJ’s,
A couple of weeks ago i posted a forum about my 10” Contractors Saw vibration. I removed the belt to see if the tablesaw would stop the vibration, the vibration was completely gone. I also read that the vibration could be because the belt isn’t aligned properly.
How do I align the belt so the it is straight?
The instructions that came with the tablesaw were pretty bad
Many thanks
-- Jackson, Australia,http://www.jacksonsfinecarpentry.com.au/
1 reply so far
View JustJoe's profile
JustJoe
1554 posts in 2273 days
#1 posted 01-16-2014 12:44 AM
If you can get a long straightedge against both pulleys you should be able to see if they are aligned or fairly close. Depending on your saw that might be hard to see.
Now that the belt is off – is it hard in any spots, can you see one or two areas that are curved to the same radius of the pulley, like maybe it sat in one position for a long time and got set that way?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
