| Forum topic by oakdust | posted 338 days ago | 1721 views | 0 times favorited | 29 replies | ![]() |
338 days ago |
Hey guys & Gals whats the best dovetail jig that will cut pins and tails at the same time. I need it for a kitchen job but would like to go 18” or longer. If I am going to buy I figure I may as wel go all out and get one for blanket chests too. -- Bob, Rockford IL, http://www.woodandwax.net |
338 days ago |
Learn from my mistake and save your money for a Leigh. |
338 days ago |
I love my Leigh Super Jig. -- My favorite piece is my last one, my best piece is my next one. |
338 days ago |
Look at the Router Boss. It won’t do pins and tails at the same time but it will handle stock wider than the Leigh or other dovetail jigs can. That’s handy for things like blanket chests. It’ll also make nicer looking, more slender dovetails if you use HSS dovetail bits. You can use absolutely any dovetail bit you wish as far as that goes. You could also do the mortises and tenons and box joints and edge profiles and… And, because it mounts on the wall, it’s always put away and it’s always ready to use. -- Until you spread your wings, you'll have no idea how far you can walk. |
338 days ago |
Stay away from the Rockler jig too. I am sure they meant well, adjustments are a pain in @ss -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
338 days ago |
Looked at the router boss awsome tool but looks like it has a high learning curve. Leigh looks the best so far. -- Bob, Rockford IL, http://www.woodandwax.net |
338 days ago |
It’s not that steep or a learning curve. In fact it’s quite intuitive. The 18” will be kind of limiting for things like blanket chests. You might want to consider the 24” at least. -- Until you spread your wings, you'll have no idea how far you can walk. |
240 days ago |
I personally use the katie jig, it is very easy to use the manual is a bit undesirable, but it is ready to go out of the box. You can cut pins on 1 side and tails on the other at the same time. but with 1 router you have to change the bits. You can use it with a hand router or table unit. I am blind and I found it very easy. |
240 days ago |
Leigh D4R But it doesn’t do pins and tails at the same time. Guess you have to pick your poison – - I am not aware of any jigs that have adjustable spacing that would cut pins and tails at the same time. That is only on the fixed spacing version. -- Its never too late to have a happy childhood. But the second one is up to you and no one else. |
240 days ago |
I’m kinda surprised that there are so little Akeda users/fans out there, personally, If I was in the market for a dovetail jig – I’d definitely go with the Akeda based on my research. but with all honesty – I have no experience with any of them, so take this with a grain of salt. I do dovetails with the bandsaw – but that can only take you so far when you consider blanket chests… -- When in doubt - There is no doubt - Go the safer route. |
240 days ago |
I bought a Keller Dovetail Jig and have been very pleased with it. Very easy to use, very quick and unlimited length capacity. It doesn’t do pins and tails at the same time, though. -- John, co-owner Sawdust 'n Stitches |
240 days ago |
I am very impressed with the AKEDA DC16 and am planning on buying one when I start doing dovetailing. Go to www.finewoodworking.com. They have a great tool review on dovetaling jigs (Tool Test/ Dovetail Jigs). Now that I typed this, I do not know if you can read it if you do not have an internet subscription. Left it in for those that do. Go to woodworking.about.com for a tool review you can read. If you go to the AKEDA sight they have internet reviews you can look at as well. Good luck on picking a dovetailing jig. God Bless -- Mc Bridge Cabinets, Iowa |
240 days ago |
I picked up the new Porter-Cable 24” Omnijig when it came out, pricey but worth it in my opinion. All the preset stops that it has including setting the router bit depth speeds up the process immensely and makes it very repeatable. I had the Leigh 24” D4R before that and that was an excellent jig also, but Porter-Cable took some of the best designs from the Leigh and added improvements. But as mentioned, being a movable finger design it doesn’t cut both the pins and the tails at the same time. -- -Curt, Milwaukee, WI |
240 days ago |
I have to echo DaveR about the router boss, the learning curve is VERY short. Some great reviews about the RB can be found on here http://www.aldel.co.uk/Contents.htm . If you have a fast internet connection, check out the woodrat video here http://www.woodrat.com/dvd.html . The RB is essentially a second generation woodrat, but I can only recommend the RB (because that’s the only one I own!). -- Let's make some firewood! |
240 days ago |
I bought a LEIGH for a similar job and when I did the 30 drawers, I sold it for almost the same money I paid…...I doubt other brands retain the value that way -- Francisco Luna, San Francisco Bay Area. |
239 days ago |
Incra LS Positioner, best dovetail and box joint and router everything you could imagine!!!! -- MARK IN BOB, So. CAL |
239 days ago |
I am a long time user of the Leigh D4 and would have thought it unlikely that anytning could beat it for making dovetails. But it has been beaten, by the Leigh D4R version. This is a real step up without messing up the good stuff, something lots of companies have to learn how to do… -- Tom Hintz, www.newwoodworker.com |
237 days ago |
D4R, love it! -- Jeremy, Baton Rouge, LA - rayburnfinefurniture.com |
237 days ago |
When it comes down to it, there is no “best” dovetail jig or “best” anything. It depends upon what you like and what sort of flexibility you need. If you like those fat dovetails that look like zipper teeth, a fixed finger jig will be just the ticket. If you want those fat dovetails made by carbide cutters but you want a flexible template to follow, the Leigh and Akeda jigs seem like the ones to look at. And if you don’t want to be limited to only fat carbide cutters or templates, there are other units to consider. If you don’t want to use a router then there are several other options I can think of. None are the best, though. -- Until you spread your wings, you'll have no idea how far you can walk. |
237 days ago |
www.newwoodworker.com Just did a tool review on the D4R dovetail machine. Very impressive machine. I would go with the AKEDA BC24 or the D4R. Both are pricey, but alot has to do with how much you want to spend. God Bless -- Mc Bridge Cabinets, Iowa |
237 days ago |
I have an older (about 20 years old) 24” Leigh jig, and I highly recommend there product for doing multiple drawers, but lately I have been doing dovetails by hand and will continue this for only a few drawers at a time. Good Luck. -- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave" |
237 days ago |
I use the Leigh 24 inch D4. It does a good job but it doesnt do tails and pins together. I have to keep the manual handy since between uses I sometimes have trouble figuring out the setup. I have ordered parts and bits from Leigh directly and have called them with questions etc…they have great customer service. -- Wayne - Plymouth MN |
236 days ago |
I also have the D4R and am very happy with it, but it doesn’t do the pins and tails at the same time. I prefer to batch cut all of my pieces anyway. I read where the new Leigh Superjigs can do this, but I have no experience with them. |
33 days ago |
I took a look at the Router Boss and was suitably impressed with the looks and concept. But then I looked at the price and was struck dumb. I would love to buy one but the price is far more than ANY single tool in my shop. Wow. -- Oshkosh, Wisconsin |
33 days ago |
This thread just goes to shows that the best dovetail jig is the one you get use to using . I have 3 different models and use each of them. -- Jim from Heirloom Woodshop Southern Oregon |
33 days ago |
Jim, you are correct. Diamondback, The price is high but compare buying the RouterBoss to buying machines to do the things you can do with it and that price isn’t so bad. I realize that might not put it in range for you but for a lot of woodworkers, it could be a good alternative to say a Leigh dovetail jig and the Leigh FMT plus maybe a router table and some other tools. It takes up less space than those things do, too. D -- Until you spread your wings, you'll have no idea how far you can walk. |
33 days ago |
I recommend the Akeda for two reasons: —Customizations are easily REPEATABLE. I don’t do production work, but I can imagine getting pretty frustrated trying to replicate a setup on the Leigh. On the Akeda, it’s EASY to repeat a setup that you made even 10 years before. —It’s idiot proof (based on my statistical sample size of one idiot :-). -- Laziness - Apathy = Efficiency |
33 days ago |
I agree that the Akeda is the way to go. I have the Leigh D4R, PC Omnijig and two Akedas. Use the Akeda all the time. I have one set up for pins and the other for tails and they fit together perfectly. I like simple and this jig is simple, but still can do through dovetails, half blind, sliding dovetails, and finger joints without buying additional templates. |
32 days ago |
I took a long look at the Akeda a year or so ago and was very impressed with the videos showing off how it worked, etc. Seems like a very nice system. I had heard at the time though that they were having problems maintaining the business and would go “under” soon. Is that incorrect? No doubt about it I really like the concept of the Router Boss, the footprint, ease of use, flexibility, etc. And I do understand the cost versus multiple capabilities argument. I would agree. Now I just need to save up the bucks and do enough dovetailing work, etc. to justify it. (Then again, the Akeda calls to me….) -- Oshkosh, Wisconsin |
32 days ago |
Akeda is alive and well. There was an issue with Woodcraft that may have created this feeling, but their sales seem to be strong and the guys I have been talking to are looking forward to moving forward with new ideas and programs. The fact that Whiteside is continuing to make router bits for the Akeda is a testament that they feel that Akeda has a long future ahead of it. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
