Anti kick back device for table saws
Forum topic by MrRon posted 01-15-2014 08:27 PM 7771 views 1 time favorited 14 replies Add to Favorites Watch
View MrRon's profile
MrRon
4794 posts in 3268 days
01-15-2014 08:27 PM
Topic tags/keywords: tip
I’m surprised no one has mounted an anti kick back device on their fence for ripping. Ripping is when kick back happens. Radial arm saws have an anti kick back device that is a toothed crescent of metal on the end of a rod placed at the outfeed end of the saw carriage. The teeth glide across the wood as you push the wood through the blade. The metal crescent digs into the wood when the blade wants to kick back. It would be pretty easy to devise a similar setup for table saws. This would be quite effective when ripping narrow strips.
14 replies so far
View LeChuck's profile
LeChuck
424 posts in 3087 days
#1 posted 01-15-2014 09:21 PM
Most recent table saws, and not so recent, have anti kickback pawls. Good safety device. Unfortunately on my saw, they leave a mark that is a real pain to sand off (since it’s dug in), and that’s not always very visible until you put some finish on it, even after sanding. I wonder if I should take a file to the bottom of the pawls to make them less sharp.
-- David - Tucson, AZ
View PurpLev's profile
PurpLev
8536 posts in 3673 days
#2 posted 01-15-2014 09:28 PM
anti kick-back pawls have been on tables saws for AGES… since the days of the splitter/blade guard and before the inclusion of riving knives.
it is exactly what you described:
View pintodeluxe's profile
pintodeluxe
5705 posts in 2838 days
#3 posted 01-15-2014 09:30 PM
Featherboards and Board Buddy rollers are other options instead of the kickback pawls. They will not mar your workpiece.
View CharlesA's profile
CharlesA
3329 posts in 1822 days
#4 posted 01-15-2014 09:34 PM
or you can spend $75 on these:
CharlesA
#5 posted 01-15-2014 09:34 PM
willie beat me to it.
View basswood's profile
basswood
261 posts in 1645 days
#6 posted 01-15-2014 09:38 PM
I use both fence and table mounted feather boards that both hold stock tight to the table and fence.
These both improve rip quality and reduce the likelihood of kick back.
Also friendlier to the wood than aggressive pawls.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View Bill White's profile
Bill White
4948 posts in 3985 days
#7 posted 01-15-2014 10:20 PM
I use pawls and Board Buddies when the work will allow. I’m a weenie when it comes to kick back.
Bill
-- bill@magraphics.us
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2131 days
#8 posted 01-17-2014 01:36 AM
I’ve never seen board buddies before. That’s pretty slick.
It doesn’t seem as though they would be very effective on narrow cuts. It looks like the narrowest cut they could make is about 2.5”. Is that the case, or is a way to set them up for narrower cuts? If so, how narrow can they go?
It does seem like a fence mounted cam style pawl would be able provide antikickback in narrower stock, for example when you’re cutting 1” spindles for craftsman style furniture. Does such a thing exist?
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2135 days
#9 posted 01-17-2014 12:48 PM
I’m good with a properly installed riving knife, and properly face and edge jointed stock.
Pawls and Board Buddies annoy me, and in my opinion, don’t add anything to a properly installed knife. If the kerf can’t close, and the stock can’t get pushed against rising teeth, the board can’t kick back. If your blade is raised at least to the bottom of the gullets, and the knife is close to the back (rising) teeth, there is no way for a board to climb on top of the blade.
Setting a blade too low can create a kickback situation, even with safety measures installed.
On my previous saw, I used to install white oak splitters to my zero clearance inserts, less than 1/4” behind the blade. I kept inserts handy that matched a bunch of blade heights. The planed to match blade thickness splitter grain was oriented vertically, securely glued in place, and the leading edge was rounded and waxed. It was a shop-made version of the Micro Jig splitter, but it could be installed much closer to the blade, built to varying heights, and it couldn’t unintentionally come out. They worked great, unless the blade was tilted…
To me, the real riving knife made a bunch of stuff invented before it’s introduction obsolete.
Nicholas Hall
#10 posted 01-17-2014 03:14 PM
I imagine there are a lot of us out there that would love to have a real riving knife!
Unfortunately, it seems like they have really only been available (except for an infinitesimal minority) in US for the past 5 years or so. Even now, I would guess that less than 1% of saws owned by Lumberjocks have a real riving knife.
The Grizzly 1023 that I work on doesn’t have one, but wired for 220V, it does have an enormous amount of power. As a result, I’m always keen to learn what other folks do to minimize the risk of kick-back. Pawls and board buddies may be a pain, but their not nearly as painful as fingers in a 20 tooth rip-cut blade at 8000 rpm!
CessnaPilotBarry: Your point about properly face and edge jointed stock is well taken, I’ve seen people try to “square the edge” of a wany edged rough cut board on a tablesaw in order to “save the jointer blades”. All the equipment in the world is worthless if you don’t at least square the edge on the jointer. It’s the kind of shortcut that can lead to long recovery times and physical therapy. I think that there are a lot of folks that make the transition to rough cut lumber that don’t understand that the jointer is one of the best pieces of safety equipment in the shop.
View Eugene's profile
Eugene
15 posts in 1911 days
#11 posted 01-17-2014 03:48 PM
This side of the pond, all table saws have an anti kick back device fitted, it’s a riving knife.
So called ‘kickback’ is caused when the timber pinches onto the rising teeth of the blade, a riving knife prevents this and kickback cannot happen.
We see all sorts of video’s on youtube of you guys using your table saws without riving knives and wonder how the heck you get away with it, obviously some don’t.
Have a look at this.
http://www.dailymotion.com/video/x7d2vt_kelly-mehler-table-saw_lifestyle
View nwbusa's profile
nwbusa
1021 posts in 2311 days
#12 posted 01-17-2014 04:44 PM
I agree with Barry and also with the video link posted above. I personally wouldn’t use a table saw without a riving knife, although I don’t have much use for the blade guard and zero use for the pawls.
-- John, BC, Canada
Nicholas Hall
#13 posted 01-17-2014 04:51 PM
Great video Eugene. That was time well spent. Kelly Mehler is a man who knows a thing or two about woodworking. It was pretty amazing to see his demonstration with the piece of styrofoam showing exactly how kick-back occurs.
If anyone has never seen kick-back in real life, you can see it up close and personal on a square of styrofoam at 11:55 seconds into the video. Even with a styrofoam “board” it’s pretty amazing to watch. The destructive force that it generates is incredible. I guarantee it you’ll work safer after seeing it in real life.
Thanks again for posting. I’ll be buying a micro-jig splitter before I fire up my saw again. Now I’ve just got to figure out where to get the money for a saw with a riving knife :)
OggieOglethorpe
#14 posted 01-20-2014 02:17 AM
One more thing…
People who use Board Buddies, without a splitter or riving knife, on a higher horsepower saw need to be aware that a pinched blade due to reaction wood may generate enough force to lift a typical fence, to which the BB’s are attached, right off the table. Most fence attachment systems resist side forces better than lifting forces. In this scenario, the BB’s become the fulcrum forcing the wood against the top of the spinning teeth.
If this happens, there will be enough crazy going on that you may touch something that you shouldn’t as you try to hang on.
BB’s can help hold well-behaved stock against the fence, preventing stock rotating and touching rising teeth, but don’t skip the splitter. Pinch events can happen instantly. Once you’ve seen a board jam solid on a riving knife, or even remove a Micro-Jig splitter from it’s mounting holes, you’ll be really glad something was back there, as you knee the OFF switch and wait for the saw to coast down.
