Mobile Bases
Forum topic by DannyBoy posted 335 days ago 360 views 0 times favorited 12 replies Add to Favorites Watch
View DannyBoy's profile
DannyBoy
442 posts in 759 days
335 days ago
Topic tags/keywords: shop question
In the midst of re-arranging my shop, I’ve realized that I’m killing myself trying to move large tools around. So, I’m wanting to buy/build roller bases for the larger items. I had read something somewhere that mentioned using a three will base on a shop floor that isn’t 100% level helps to keep tools from rocking dangerously.
Does anyone have any experience with this that can help me find a produced one or build ones that are stable and safe?
~DB
-- He said wood...http://hickbyassociation.blogspot.com/
View Woodchuck1957's profile
Woodchuck1957
950 posts in 658 days
335 days ago
Some of the HTC mobile bases are 3 wheel.
View Kindlingmaker's profile
Kindlingmaker
1470 posts in 420 days
335 days ago
I have both 3 and 4 wheel HTC and I hope there are better ones out there. They work ok, good on the bandsaw base but the table saw, well, I think there has to be a better design. They will move the equipment when needed. I lean towards “rock solid” and “hell for stout” and HTC does not come to mind when I think of mobile bases.
Woodchuck1957
335 days ago
My favorite mobile base is the Delta 50-345, it is a universal mobile base meaning you can make it any size you want. I like it because if I ever sell a piece of equipment that it’s on, I can keep the mobile base and size it for the next piece of equipment. It has 3 wheels, but when lowered the wieght rests on two of the wheels and two adjustable rubber feet. I supose if you have a floor thats not level, you could find a spot you want your saw in when working and adjust the rubber feet. You may want to mark the floor somehow so the next time you wheel out the saw you know exactly where to put it so it doesn’t rock.
DannyBoy
335 days ago
Now that sounds like what I’m looking for. Thanks, Woodchuck!
View 8iowa's profile
8iowa
592 posts in 655 days
335 days ago
A thought to ponder is the fact that the alignment on a machine can change after it is moved to a different location, especially if the floor is uneven.
View Frostyjo's profile
Frostyjo
17 posts in 404 days
335 days ago
This is an old MC lift that I removed the lift mechanism from. Lift The next time I need a base I’m going to have a metal shop make me one following this basic design. With the casters mounted outside the base area it sits low to the floor and you can use larger casters that support more weight and roll easier. By having one made it will fit the tool base/cabinet and you can have it made longer than needed if you want to build a storage cabinet for accessories. It will probably cost you less and you will get a better product.
Frosty
-- If you can't fix it with a hammer, you have an electrical problem.
Woodchuck1957
335 days ago
Frosty I think you did a good job of useing something that was no longer working. How does it stay in place after moveing it ? I do think though that you’ll find that haveing someone make it won’t be very cost effective. Kind of like custom furniture verses mass produced, custom almost allways costs you more, plus have you priced out casters and metal nowdays ?
Frostyjo
335 days ago
No I haven’t priced casters or steel lately. In truth, I’m a scrounge. There always seems to be someone that has some scraps (like old steel bed frame rails) that they will part with for a 12 pack or a future favor. Welding will cost extra :).
It has bolts in the swivel caster end that screw down until the casters come off the ground. They also make it easy to level. I’ve seen the design on pre-made bases (Grizzly) and it seems to work well enough. Someday when I have a few extra dollars I’ll change the bolts out for ones star knobs so I don’t have to use a ratchet.
Frosty
View mski's profile
mski
360 posts in 874 days
334 days ago
Dannyboy, Rockler has this one on sale, free shipping!
http://www.rockler.com/product.cfm?page=2383
-- MARK IN BOB, So. CAL
View Garyb6's profile
Garyb6
262 posts in 524 days
334 days ago
I recommend considering building your own mobile bases. I have gone both ways, buying and building and I find that shop built ones are more sturdy and usually less costly. You can do a search on this site for mobile bases and find examples and other useful info.
My 2 cents.
-- Garyb6, “Make everything as simple as possible, but not simpler” - Albert Einstein
View toyguy's profile
toyguy
717 posts in 731 days
334 days ago
Then if you want Hi-Tech check out this system:
Hover Pad
View pitchnsplinters's profile
pitchnsplinters
252 posts in 332 days
331 days ago
My only advice is to steer clear of 3-wheeled bases for equipment with a high center of gravity, such as a floor model drill press. They can be quite tippy when being moved, and sometimes when parked.
Most 4-wheel bases available commercially have leveling feet for when the tool is parked. You can definitely pull off the same in a shop made base.
Good luck.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
