Help with half blind dovetails and Drawer construction - Incra System
« back to Joinery forum
Forum topic by misterbig posted 01-14-2014 07:12 PM 1702 views 0 times favorited 3 replies Add to Favorites Watch
View misterbig's profile
misterbig
46 posts in 1883 days
01-14-2014 07:12 PM
I have a Incra System and was going to build some pull out kitchen drawers for my pots and pans and have a question regarding calculating the drawer dimensions. Normally i use Pocket holes and cover the front of the drawer with a fifth board to cover the pocket holes.. because this drawer will be in side the cupboard I will not have a way to hide the Pocket holes… I was thinking that this would be a good project to try the Incra system out and do Half blind dovetails. I watched the video, read the book and I think i am pretty solid on how to set up the system to cut the pins and tails. the question i have though is how do you calculate the tail length to accommodate the amount that will insert in the pin board.
Eg I would like to have a 22” deep x 25” wide draw box.
the width i would imagine would be just 25” as the tails will be flush with the outside edge of the board.
the thing i do not understand is based on the patterns in the master ref guide it doesn’t advise how long the dovetails will be on the tail board. I would imagine it will be a in the ball park of a half inch or so shorter then the final 22” depth.
sorry for such a basic question as i am just starting out and looking for some advice.
m
3 replies so far
View lepelerin's profile
lepelerin
495 posts in 2530 days
#1 posted 01-14-2014 07:38 PM
cannot help I do not have an incra. Make a test piece and this will simply answer your question. This is the only advice I can give. Sorry.
View jakep_82's profile
jakep_82
105 posts in 2511 days
#2 posted 01-15-2014 08:05 PM
It depends on the bit you’re using. For a 1/2” 14 degree bit, the cut depth is approximately 1/4”. The only way to know the exact dimension is to follow the setup instructions to figure out the exact cut depth. It’s a simple process that require a couple small pieces of scrap and it’s detailed in the book and on the video.
Smitty_Cabinetshop
15704 posts in 2824 days
#3 posted 01-15-2014 08:14 PM
Half-blind tails extend around 2/3rds into the face board on drawers; the third that is not cut to accept the tails is the distance to be subtracted from the length of the drawer’s sides. A way to make this happen is to complete the half-blind joints then cut the sides to the desired length from the back end afterward.
But that’s input from a one that does it with hand tools and doesn’t measure much of anything at all; your mileage (and preferred practice) will vary.
A look at the process I’ve used is here and here.
