Which Glue?
« back to Joinery forum
Forum topic by Dallas posted 01-14-2014 06:14 PM 1749 views 1 time favorited 17 replies Add to Favorites Watch
View Dallas's profile
Dallas
3599 posts in 2358 days
01-14-2014 06:14 PM
Lately I have been doing a lot of guitar repairs. Broken and cracked headstocks, scarf joints, necks, etc.
I also have some Autoharps I need to get back into shape.
I started out using Titebond III, which didn’t seem to have a long enough working time, then I used Titebond II on another repair and it just felt rubbery after curing, I’m not sure how to describe it, but it was completely wrong for the repair I was trying to make.
The last repair I made was using Gorilla Wood Glue which worked better than the TB II (Equivalent), and it is plenty strong and holds tighter, doesn’t seem as flexible….. BUT after 3 days of drying and during final sanding it kept expanding out of the repaired break, looking something like rubber cement that you rub and ball up between your thumb and fore finger.
I dug as much out as I could with a dental pick and filled the crack with Super Glue Gel and sanding dust.
This worked, but there has got to be a better way.
I have been looking at real hide glue, so far something like 192 cut or even 256, I’m not sure.
I need help on deciding which I should get and what brands are good.
I looked on eBay and a lot of this stuff comes from the west side of the “Ring of Fire” and I’m not too keen on that idea.
One of the brands I have narrowed it down to is this: CLICK HERE YOU BIG OL' LUMBER JOCK!
Will this stuff dry harder with less problem when sanding?
HELP!
17 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1909 days
#1 posted 01-14-2014 06:20 PM
This is the hide glue I’ve used in the past. (Not for a guitar repair though).
http://www.toolsforworkingwood.com/store/item/MS-HIDEGL.XX/Hide_Glue
I used the 192. If you’re fixing necks maybe you could try the 315.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View lumberjoe's profile
lumberjoe
2894 posts in 2119 days
#2 posted 01-14-2014 06:20 PM
For joints that you just can’t get clamps on, I love hot hide glue. Actually I use it for almost everything anyway (except cutting boards). 192g is what I use. It really is amazing stuff and I can’t believe more people don’t use it. With tight fitting joints you really don’t need clamps at all. If you don’t believe me, make a couple rub joints, don’t clamp them, and try to break them apart the next day.
Also the cold water cleanup is awesome, and unlike PVA glues it has no effect on finishes. In fact some even use heavily diluted HHG to pore fill.
View Loren's profile
9763 posts in 3519 days
#3 posted 01-14-2014 06:26 PM
Hide glue doesn’t seem very effective at filling gaps to me. It
has some interesting and useful characteristics otherwise. If
you can get your joints accurate, hide glue might be
a good choice.
I like fish glue for fussy little repairs. It grabs real quick.
My general shop glue is Titebond 2 Extend… I do not think
it is the same as Titebond 2 since it is rated for hot press
and radio frequency gluing, which is why I use it. It seems
to cure reasonably brittle. On the hot edgebanding press
I haven’t seen it creep after curing. I don’t think the
heat does anything but speed the curing but it is
possible it makes the glue cure harder.
View shipwright's profile
shipwright
7847 posts in 2669 days
#4 posted 01-14-2014 11:51 PM
I use Milligan and Higgins 192gram almost every day. It is excellent stuff. For instruments in high stress areas you may want to go for a little higher gram strength but 192 is equivalent most “modern” wood glues. The higher the gram strength however, the shorter the working time.
If you are new to hot hide glue check this blog.
View Texcaster's profile
Texcaster
1266 posts in 1545 days
#5 posted 01-15-2014 01:07 AM
I get my HHG from LMI, #192 gram. Avoid the pre- mixed stuff, it is rubbish.
-- Mama calls me Texcaster but my real name is Mr. Earl.
Dallas
#6 posted 01-15-2014 02:51 AM
Thanks all. I really want to try this stuff because I am tired of the problems with regular PVA glue.
Loren:
How does fish glue work and does it become solid or does it stay flexible? that’s the problem I am having with the PVA’s, they stay a bit flexible and rubbery which I can’t have when trying to re-attach a neck.
Texcaster
#7 posted 01-15-2014 03:43 AM
I have not tried fish glue and I think I’ll wait a bit after reading this.
http://www.anzlf.com/viewtopic.php?f=1&t=5927
shipwright
#8 posted 01-15-2014 03:56 AM
Fish glue has a little more give than hide glue. It was used to glue non wood items like shell that have different expansion characteristics from wood. The drawback is that it is not water resistant. Hide glue requires heat and moisture to reverse it. Fish glue only moisture. This can be used to advantage when you want to be able to disassemble something easily.
View JAAune's profile
JAAune
1772 posts in 2188 days
#9 posted 01-15-2014 06:29 AM
If the joints are not tight and you’re dealing with gaps I’m curious why you’ve not used epoxy yet? It definitely gives plenty of open time and it’s about the only glue I’ll trust for joints that aren’t tight. I’ve actually used epoxy to repair a broken guitar neck and it worked out fine.
Regarding Gorilla glue, since it cures by moisture, it may be possible to speed up the cure by spritzing one side of the joint with a little water before clamping.
Dallas
#10 posted 01-15-2014 11:02 AM
Thanks Bill and PAul, I think I’ll wait on the fish glue also.
JAAube, Gorilla Wood Glue is not the same as Gorilla Glue. It doesn’t cure with moisture.
It is a PVA, (Polyvinyl Acetate) like Tite Bond wood glue.
There are no real gaps in the joints, it is just the wood glue that has cured that excretes fron the tight joint like a little fine line of rubber. When doing a shiny gloss finish like lacquer, any blemish will show up.
Epoxy, as far as I know isn’t recommended for musical instruments. It changes the resonace qualities of the wood, although I probably couldn’t hear the change.
View Ted78's profile
Ted78
344 posts in 1871 days
#11 posted 01-15-2014 11:21 AM
From what I’ve read hide glue will not fill gaps, though as you state I can’t imagine your filling gaps wit glue in guitar joints. I’ve been playing with Knox gelatin just because it was quick easy and cheap for me to get (as in dig into the back of the cupboard) Seems to work reasonably well. Seems to have a fairly long open time, I expect (but don’t really know) it has a fairly low gram strength and is probably more akin to a bone glue than superior? hide glue, but might be something to try.
-- Ted
JAAune
#12 posted 01-15-2014 06:03 PM
I hadn’t realized you were referring to Gorilla PVA glue since I skimmed right over that part of the OP. Sorry.
You’re probably right regarding epoxy and musical instruments. I’m sure it would be problematic if used on the body of an instrument but I’m not sure it would cause any issues when used on the necks. The repair I did was on an electric guitar anyway so acoustics weren’t that big of an issue.
Check into veneering PVA glues. I’ve used Unibond 1 from Vacuum Pressing Systems and it’s much harder than most PVA glues. It’s about the same price as Titebond III.
Hide glues are the standard in the luthier trade though. It would definitely be worth getting accustomed to using those types of glue.
Dallas
#13 posted 01-15-2014 10:35 PM
Thanks Ted, I had thought about that, I’m just not sure gelatin could handle the stress of constantly holding a neck under the strain of the strings.
I also thought about sticking a bunch of rawhide chew toys in a pot of boiling water for a half a day and seeing how they worked for glue.
JAAune, I don’t have that much experience with guitar repairs. I was told by a friend who is a luthier that any changes in density makes a difference in tonality, whether it’s in the body or the neck or whether it’s a solid body electric or a arch top F hole.
As I gain experience maybe I can learn more and not need to ask so many questions.
Craftsman on the lake
2728 posts in 3309 days
#14 posted 01-15-2014 10:43 PM
Modern guitars are held together with yellow glue like titebond. The fretboard is glued on with white glue like elmers as it can be removed with heat. A nasty trick is when I come across a fretboard repaired and glued on with yellow glue….. You have to almost chisel it off.
Hide glue is only used for the violin family of instruments as technically, professional ones are supposed to be disassembled each year and reglued. Hide glue allows for this without damaging the wood.
View Wally999's profile
Wally999
1 post in 1046 days
#15 posted 05-04-2015 03:26 PM
As a follow-up to the use of hide glue on autoharps I Strongly suggest Not using it. All the luthiers I Have discussed this issue with recommend a titebond type glue. The pressures in an autoharp are far greater than in guitars. I had on friend who assumed hide glue would work on two autoharps he built. They both collapsed when the humidity got above 90%!
