TIMBERMATE-wood filler
Forum topic by jockmike2 posted 729 days ago 1130 views 0 times favorited 10 replies Add to Favorites
View jockmike2's profile
4437 posts in 774 days
729 days ago
I don’t know how many of you use wood filler, I imagine most, but I’ve found a product I first read about in popular woodworking called Timbermate. It’s some pretty incredible stuff. Water soluble, it takes stain well, if it dries out you just add water and it reconstitutes. After sanding you can sweep up the dust, add water and reuse it. It comes in about 8-10 colors that you can mix and match I’ve even added food coloring to tint it or cloths dye. I order mine from Jim Carrolls store in Australia where its made, I could’nt find a local distributor. It’s fairly cheap. It was originally made for filling and finishing floors. But they found carpenters liked it also. You can find Timbermate on the internet and maybe find a local distrbuter, there was one in chicago, but I did’nt have any luck with them. If you want Jims number contact me and I’ll post it. Did I say it does’nt freeze either. jockmike2
-- Mike. Profisher50@yahoo.com
Dick, & Barb Cain
5372 posts in 827 days
728 days ago
Hi Mike,
Interesting, I looked it up on the internet, & here’s one of its sellers.
http://www.woodworkersshop.com/Timbermate_Water_Based_Wood_Filler.htm
728 days ago
It’s good stuff Dick, I’ve been using it for 3 years now but iI order it from “Carrolls Woodcraft Supplies 66 Murradoc Rd. Drysdale Australia 3222 . AUS PH 03 5251 3874 fax International 61 3 5251 3864 web address Carrolls@pipeline.com.au a couple other things, this stuff does’nt shrink and it smells like band aids. These people are trustworthy they send out your order the same day they get it from you, it only takes about a week to get here. I’ve had better service than alot of American companies.jockmike2
View Don's profile
Don
2586 posts in 705 days
696 days ago
Yes, Dick, as Mike stated it’s a good product. Carrolls Woodcraft is not far from where I live and Jim Carroll runs a good little company. Here’s his web site. The link that Mike provided is his email address.
-- CanuckDon "I just love small wooden boxes!" http://www.canterburybaptist.org/
View oscorner's profile
oscorner
4573 posts in 839 days
695 days ago
I haven’t used any wood filler before. I’ve looked for it at the local box stores, but never knew which brand was a good one. Thank you for your post. Now I know which one to get. I mostly use a sanding sealer, then shellac or poly for my finish coats. Olive oil makes for a good finish also. What I like about using olive oil is that I don’t have to worry about getting it on my hands. It’s safe, unlike most other oils. What types of woods/projects do you use wood filler on?
-- Jesus is Lord!
695 days ago
Hi Oscorner, joust use it on any type of wood that you have a scratch or a deep hole in andl let it dry, sand it and paint or stan it, and you’re done. mike
View Don's profile
Don
694 days ago
The issue of filling gaps in fine woodworking is a non sequitur. If the gap is any bigger than .5mm, it is usually sloppy woodworking. Filling anything larger than this with a filler, unless the finish is paint, leaves an unsightly visual reminder of poor workmanship. It will remain there forever reminding its creator of lazy or sloppy work practices. Regardless how good the filler is, it is normally visible – and that’s a bad thing, to paraphrase Martha Stewart.
Having said that, I find that when doing dovetails, and other intricate joinery, it is not unusual for there to be small gaps, less than .5mm. My method of filling and disguising these is to use a burnishing oil. The process is very simple. Using a random orbital sander, and an ample application of burnishing oil, tung oil will do, sand over the joint (and the rest of the adjacent surfaces). Do not use a dust extractor. This allows the sanding dust and oil to build up a slurry. This slurry, perfectly matched in color, works its way into the small gap completely hiding it from the eye. When the oil dries and hardens, the fix is permanent, and completely invisible.
692 days ago
You’re right of course Don, Timbermate was originally made for wood floors. Its handicapped people like me that probably made a market in the wood filling business. I’m lucky if I can do anything without a little touchup somewhere. Thanks for that observation. mike
View Don's profile
Don
692 days ago
Mike – I was not directing my comment towards you, or anyone specifically. I just thought it was a good idea to maintain, and declare that we Lumberjocks have a high standard.
More importantly, I thought people might like to learn about the magic of burnishing. I use it all the time when making my boxes. The thing about box making is that I believe it demands a fairly high level of accuracy. Because of their small size, people pick up each one and examine them more closely that they would a piece of furniture. And because the joinery is such a prominent feature of small boxes, even the smallest of fit discrepancies cry out to be noticed.
View scottb's profile
scottb
3037 posts in 855 days
692 days ago
Don – Small boxes and Chess boards I’d say – very close scrutiny.
I can say that previous owners of my house were clearly not lumberjocks. Lucky for it now that I’m here to make up for all the bad years.
-- I am always doing what I cannot do yet, in order to learn how to do it. - Pablo Picasso -- http://snbcreative.wordpress.com/
692 days ago
I was’nt offended Don you were right, it probably was people with lesser skills that made it successful as a wood filler. mike
Bookmark And Share This Page
