First time poster here. How would I cut this?
Forum topic by woodworker81 posted 01-14-2014 04:44 PM 1102 views 0 times favorited 12 replies Add to Favorites Watch
View woodworker81's profile
woodworker81
3 posts in 1595 days
01-14-2014 04:44 PM
Topic tags/keywords: cutting
Hello everyone. I’ve been watching this forum for a while.
Finally signed up.
I have a 4×4 that I need to cut.
How would I cut it safely and accurately.
Hopefully the picture uploaded.
I want to avoid cutting and then gluing the little corner back.
Thanks in advance.
Andy
12 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1833 posts in 1969 days
#1 posted 01-14-2014 05:06 PM
I hope I am understanding you correctly here. Is it about 7 to 10 inches or so? And what is it for?
Just guessing now, but if you have a router you could do it with that, with a rabbeting bit and then clean it with some chisels. Or you could just use a chisel and a mallet and some straight edges to do it.
You could also make it a little easier by make small cuts with a handsaw into the work, to relieve the chisel a bit.
-- Just trying to build something beautiful
View ScrubPlane's profile
ScrubPlane
190 posts in 2195 days
#2 posted 01-14-2014 06:09 PM
I agree with Kaleb that a router and chisel would work.
Another option is a drill press. Drill out as much as possible and then chisel out the remaining material.
View lepelerin's profile
lepelerin
495 posts in 2324 days
#3 posted 01-14-2014 06:32 PM
A router would be the easier way or a chisel would do it too.
woodworker81
#4 posted 01-14-2014 08:07 PM
I don’t think that my router bits will go that deep.
It will be 6” from the end.
I’ll try a scrap piece on table then glue the end to show what I need. It’s for a table.
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#5 posted 01-14-2014 08:13 PM
If it is too deep for a router then waste away most of it on the drill press w/ Forstner bit and clean up w/ chisel.
-- Bondo Gaposis
View Wildwood's profile
Wildwood
2306 posts in 2134 days
#6 posted 01-14-2014 08:23 PM
Would use a hand saw to notch ends. Then use my circular saw set to depth cut long way on both sides as far as possible. Chisel out what could not cut. If had a table saw would use that vise circular saw.
-- Bill
View DKV's profile
DKV
3940 posts in 2503 days
#7 posted 01-14-2014 08:41 PM
What are you making?
-- This is a Troll Free zone.
View larson1170's profile
larson1170
32 posts in 1611 days
#8 posted 01-14-2014 08:44 PM
You can pick up a cheap oscilating saw from harbor freight for about $20. I used one last year to notch out a 4×4 for a sign and that worked pretty good.
woodworker81
#9 posted 01-14-2014 08:46 PM
There will be 2 of these. the ends of the table top.
Cuts will be underneath.
Smitty_Cabinetshop
15353 posts in 2618 days
#10 posted 01-14-2014 09:19 PM
I do like Bill’s suggestion: Use a hand saw to notch ends, then a circular saw set to depth; cut long way on both sides as far as possible and chisel out the rest.
Another possibility, if there were many of these to do, is rip the 4×4 in half via bandsaw, make your half lap cut on one, the glue them back together. That’s drastic, but if there were many on the board I’d consider it over all the chiseling if fit and finish were paramount.
View Monte Pittman's profile
Monte Pittman
29228 posts in 2337 days
#11 posted 01-14-2014 09:42 PM
Router and chisel
Welcome to lumberjocks
View blackcherry's profile
blackcherry
3338 posts in 3822 days
#12 posted 01-15-2014 02:59 AM
Hogging out with forstner bits and cleaning up with chisels would be my bet…BC
