Need some joinery ideas for this window shade
Forum topic by Rob Vicelli posted 01-14-2014 02:17 AM 759 views 0 times favorited 2 replies Add to Favorites Watch
View Rob Vicelli's profile
Rob Vicelli
104 posts in 2807 days
01-14-2014 02:17 AM
Topic tags/keywords: question walnut
HI, Maybe a fellow LJ has some other ideas or has built something like this before and can share. I am building a Sliding window shade, it has been requested to be made from Walnut. I have decided on the slide hardware. The layout will be like the attached picture, the outer frame will be doweled/glued as will the shade frame. I just cannot decide how to do the grid. The depth of the mullions? (grid) will be 1/2” and width of each piece is 3/4”.
I feel the vertical center piece should be solid (1 piece) but not sure about joining it to the frame? Do I have to worry about expansion? Should I dado & lap joint and glue or screw? Should I dowel? Pocket screw?
As for the Horz pieces I have pretty much the same questions.
Thank you for any input.
-- Rob V
2 replies so far
View hobby1's profile
hobby1
341 posts in 2413 days
#1 posted 01-14-2014 02:23 AM
I would half lap the whole grid, hor. and vert. pieces, and do a stop dado on the frame back, with a router, and dado the ends of the grid to fit the frame dadoes.
Rob Vicelli
#2 posted 01-14-2014 01:38 PM
Thanks Hobby1, I feel that may be the best route also.
-- Rob V
