scroll saw blade clamps driving me nuts
« back to Scrollsawing forum
Forum topic by Ted78 posted 01-13-2014 07:56 AM 3365 views 0 times favorited 9 replies Add to Favorites Watch
View Ted78's profile
368 posts in 1935 days
01-13-2014 07:56 AM
Topic tags/keywords: blade holders delta question scroll saw scrollworking
I have an older Delta scroll saw that uses two little clamps with Allan head bots to hold onto the pin-less blades. No matter how tight I get them, (I’ve bent cheap wrenches and snapped good ones doing so), they refuse to hold onto the blade. I’m pretty sure I am not over tensioning the blades based on what I’ve read about what it should sound like when you pluck it and how much the blade should move back when you start sawing.
The blades are not breaking, they are slipping out of the holders. They are fairly thick, robust blades if that makes any difference, not doing fine fretwork, just some work a bit to fine for the bandsaw. I’m at my wit’s end. I’m wondering if it’s something wrong with the saw itself as the blades seem pretty firmly gripped in the holders but pop out when trying to cut something with the saw. Any help would be greatly appreciated.
-- Ted
9 replies so far
View Vinnie's profile
101 posts in 3324 days
#1 posted 01-13-2014 02:03 PM
Ted, Take the bolts out that hold the blade and ruff sand the ends that hold the blade. The ends of those bolts have become real smooth and won’t hold your blades anymore. See if that helps.
-- Personalized name signs, Ham Radio Call Signs signs, home decor and more!
View Jim Finn's profile
Jim Finn
2641 posts in 2857 days
#2 posted 01-13-2014 03:00 PM
Also, be aware that cutting on a scroll saw is VERY MUCH slower than cutting on a band saw. Do not push too hard or the blades may pull out or break.
View Notw's profile
629 posts in 1688 days
#3 posted 01-14-2014 04:18 PM
I have a Shop Fox scroll saw that has set screws that are allen head to hold the blades as well. I quickly got very annoyed at having to use the allen wrench to tighten and loosen so I cut a 1/4” plywood knob on the scroll saw then gorilla glued it onto the end of a longer set screw from HD so i can loosen and tighten by hand with no tools.
View oldwormy's profile
16 posts in 1825 days
#4 posted 01-14-2014 11:16 PM
Try sanding each side of the ends of the blade before inserting in the holder. This will remove any oils left from manufacturing and rough the ends so that they will not slip.
-- AlW
View tuffruss's profile
38 posts in 2317 days
#5 posted 01-15-2014 04:31 AM
Get new set screws they will have a cupped end. They won’t slip. Good luck Russ.
#6 posted 01-15-2014 07:39 AM
Thanks for the suggestions. I will try roughing up the blade ends and see if that helps. The ends of the bolts don’t actually come in contact with the blade at all. the holders have a vertical slit that runs about 3/4 of the way to the top and the bolt runs through the slit horizontally just above where you insert the blade and when you tighten the bold if pinches the slit closed on the blade.
-- Ted
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3987 days
#7 posted 01-15-2014 06:38 PM
Possible to put some of that Thread Locking stuff on the screws to make it harder for them to loosen?
... not the REAL TIGHT stuff… maybe Light or Medium hold?
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View SCOTSMAN's profile
5849 posts in 3520 days
#8 posted 01-15-2014 09:12 PM
A few years back I bought an expensive scroll saw made also by Delta it was a top notch saw with what was said to be at the time comes with latest ( quick change tensioner blade holders).I too have had nothing but trouble with them and sadly the saw sits here never been used in about four years I spent ages trying to get them to hold without success hours at a time and finally gave up. Alistair
View crowie's profile
2321 posts in 1886 days
#9 posted 01-16-2014 10:49 AM
G’Day Ted,
I realize this could be a silly thing to suggest and apologies in advanced.
BUT is it possible to go direct to the Customer Service Dept of Delta and ask them how they’d correct the problem on there machine, especially when Alistair confirmed he too had/has a similar issue.
Just my thoughts…..
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
