Two problems
Forum topic by Bearpaw posted 01-13-2014 02:58 AM 884 views 0 times favorited 2 replies Add to Favorites Watch
View Bearpaw's profile
Bearpaw
257 posts in 3959 days
01-13-2014 02:58 AM
Topic tags/keywords: oak popular finishing question
I made foot stools from the cross section of a popular tree. It is about 2 to 3 inches thick. I have tried to control the drying, and it is to the point that it needs to be sealed. What would be best to use?
Second problem. I recently read of someone finishing an open grain wood by using an oil finish, sanding it while still wet creating a slurry that became like a wood filler resulting in a very smooth finish. Is their someone out there aware of this procedure? If so what? I am building a red oak table and getting close to needing to finish it.
-- "When we build, let us think we build forever." John Ruskin
2 replies so far
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1876 days
#1 posted 01-19-2014 01:30 AM
I can’t answer the foot stool question. But I have done the slurry with oil. Sand it while wet and it acts like a pore filler. When you wipe it off after sanding wipe across the grain. Otherwise you have a tendency to wipe the filler out of the grain. It works great on oak because of its open grain structure. Good luck
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
Bearpaw
#2 posted 01-19-2014 03:39 AM
Thanks for the feed back. I hope the weather is warmer next week to get in to the shop. I called WATCO service line to inquire about the slurry. They said it would work. My next question deals with staining. Can it be stained before or after the tung oil? I will have to test that. I will let you know.
