Ever see crown molding wrapped around a tight curve?
Forum topic by basswood posted 01-13-2014 12:57 AM 2581 views 0 times favorited 30 replies Add to Favorites Watch
View basswood's profile
basswood
261 posts in 1494 days
01-13-2014 12:57 AM
Topic tags/keywords: crown molding bullnose corner
Here is another of my projects that is worth a discussion.
Anyone know how I did this?
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
30 replies so far
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#1 posted 01-13-2014 01:02 AM
collins foot
basswood
#2 posted 01-13-2014 01:03 AM
That cropped too much off. I’ll try another pic:
basswood
#3 posted 01-13-2014 01:04 AM
@ waho,
I do cope inside corners.
I meant to ask about the outside corner curved around the bullnose corner.
View wseand's profile
wseand
2796 posts in 2915 days
#4 posted 01-13-2014 01:07 AM
It’s hard to see the corner in the pic but I would assume either lots of small angle cuts, or you cut lots of slots in the back side, or i have no idea. Used plaster, steamed it?????
wseand
#5 posted 01-13-2014 01:07 AM
I see it now.
View DKV's profile
DKV
3940 posts in 2378 days
#6 posted 01-13-2014 02:06 AM
Makes my eyes cross…
-- This is a Troll Free zone.
13594 posts in 3215 days
#7 posted 01-13-2014 02:11 AM
mitered segments
bondo
sanding
View dawsonbob's profile
dawsonbob
2699 posts in 1629 days
#8 posted 01-13-2014 02:15 AM
I’ve seen one kind of like that…but it was formed plastic, and not as nice as yours.
-- Mistakes are what pave the road to perfection
View Jim Baldwin's profile
Jim Baldwin
55 posts in 2232 days
#9 posted 01-13-2014 02:22 AM
Is this a test?
What I can see of it looks like a small outside corner-round.
I’ve turned these on a lathe mandrel from paper-glued blocks with a hole through the center (just like the base moldings) 4 corners at a time. I once had an 8ft circle crown turned on an outboard lathe faceplate. I’ve also milled them from solid stock on a shaper in stacked milling operations
Radius crown manufactured on-site from alternating strips, ripped vertically from two straight pieces of molding. The strips are applied one against the other and directly to the curved walls or forms.
Finally on large radius application, the crown can be milled in flat arcs. The arc segments are made to equal the base of an inverted cone which is equal to the radius of the desired curve. “Sprung Molding”
-- Jim Baldwin/jimhbaldwin@gmail.com
View DKV's profile
DKV
#10 posted 01-13-2014 02:35 AM
Look at it differently. As wseand said, “I see it now”.
View BArnold's profile
BArnold
175 posts in 1706 days
#11 posted 01-13-2014 03:34 AM
Turn it on a lathe with a small tenon in the chuck. Shape the outside, then hollow the inside. When finished, quarter it and you have enough for four corners.
-- Bill, Thomasville, GA
View tefinn's profile
tefinn
1222 posts in 2311 days
#12 posted 01-13-2014 03:49 AM
I do it by cutting segments then filling and sanding. Standard way of doing it. That looks like a very tight corner, nice work.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View John 's profile
John
253 posts in 3275 days
#13 posted 01-13-2014 03:51 AM
Rip Crown into narrow strips then attach one strip at a time or use a small form. The only problem is you need 20’ of molding to cover a 4’ section. All depends on how many strips you need to rip it into and that will depend on the profile. REAL PITA but the finished product makes a big difference. Nice Job!!!
-- John
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1601 days
#14 posted 01-13-2014 03:53 AM
I doubt you did it this way, but another method would be to use a hot wire and cut it out of a block of Styrofoam then coat it with drywall mud, sand to finish.
View DKV's profile
DKV
#15 posted 01-13-2014 07:54 AM
The second picture looks like a counter top.
showing 1 through 15 of 30 replies
