Lighting: Help me understand the difference between T8 and T12
Forum topic by Lee Barker posted 01-12-2014 04:48 PM 2297 views 0 times favorited 25 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 3051 days
01-12-2014 04:48 PM
Visited a friend’s shop this week and he has a new, 4 tube 4’ T8 light fixture, hung directly over his workbench (but safely above it).
It is uncanny, this desire to want to be in that light. It is magnetic, in a sense. That’s a visceral response; the intellectual one is, boy, I can really see everything very clearly here.
Once the electrician had installed the light and turned it on, the owner said, “Put me on your schedule to come back and do two more.”
I’d like some good information on the difference, both functional and investment (installation and operating cost) and anything else that would help those of us who are in the dark make an incremental improvement in that state of affairs.
Kindly,
25 replies so far
View TravisH's profile
TravisH
627 posts in 2136 days
#1 posted 01-12-2014 04:55 PM
A lot of what you describe is the K rating of the bulb. Cost between t8 and t12 is virtually the same unless we get into lighting building the size of stadiums (becomes more about the ballasts used).
View JustJoe's profile
JustJoe
1554 posts in 2239 days
#2 posted 01-12-2014 05:08 PM
T12 are phased out, no longer being produced, obsolete.
That should make it a bit easier to pick T8 or T5.
The T means tube, the number is the diameter in 1/8 (T12 is 1.25”, T8 is 1” diameter).
The smaller the diameter, the more efficient to an extent.
For the 48”, a T12 is 78 lumens (brightness) perwatt, and a T8 is 90 an T5, if you have the $, is 99.
And the color rendering index (CRI – wavelengths covered, bigger makes it look more natural) is better too.
For T12 it was low 60s, for T8/T5 it is mid 80s.
Because of the new regulations phasing out T12 and incandescents I’m sure the internet is full of sites that can explain it better than that if you try googling “difference between fluorescent lights” or “T12 vs T8 vs T5” might get you something better.
My workshop is full of 8’ T12s. I hope they don’t burn out before I die.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View tefinn's profile
tefinn
1222 posts in 2638 days
#3 posted 01-12-2014 05:10 PM
Hey Lee, there’s not a lot really to say about them. The T8’s use less electricity than T12’s and put out brighter light. The T12’s are no longer made in the US, so the cost of the T8 fixtures has dropped and is now comparable to what the T12’s were. They install exactly the same as T12’s. If you have T12 fixtures, you can even convert them to T8 (the pins and length for both types are the same) by changing the ballast and installing new T8 tubes. The ballasts cost the about the same as the old T12’s did. I bought mine at HD for about $15 each.
As far as operating cost, they do save money on the electric bill. I grow tropical plants/orchids (my other hobby) under lights and have six, three shelf stands with a two light fixture on each shelf. That’s 24 light fixtures with 48 bulbs that run for 12hrs a day. After converting them all from T12 to T8 my electric bill dropped over $40 a month.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
JustJoe
#4 posted 01-12-2014 05:13 PM
Tom – please explain (maybe in another post or an instructional blog) how to do that ballast changeover. I’ve got 4 of the 2-tube 8’ fixtures and a couple of the smaller ones and only one T12 spare bulb left.
Edit: Thanks.
TravisH
#5 posted 01-12-2014 05:18 PM
Wood… Best-Ever Home Shop Ideas 2013 (Displayed until December) has a 4 page article on shop lighting.
13640 posts in 3542 days
#6 posted 01-12-2014 05:20 PM
i had a slew of t-12 fixtures i got on sale years ago
put 12 of them up in my spray booth
(so i don’t have to bend over and move around
to see the actual work surface)
got a bunch of t-12 tubes for them
but only a few worked the rest flikered or didn’t light at all
returned them and got other boxes
(one turned out to be some guys old ones
he had taken back and got his money back
as if they were new in the same box)
well it turns out the ballasts were no good in my fixtures
and they don’t even sell them on ballast sites either
(cheap stuff works that way)
so now i am looking for enough money to get the t-8 fixtures
as i have 24 brand new t-8 tubes
i will ‘watch’ this page
for more info on this too
thanks lee for this post
View Bill White's profile
Bill White
5124 posts in 4161 days
#7 posted 01-12-2014 05:26 PM
I have 8 two tube T-8 fixtures in my shop. 9 foot ceilings painted a slight off-white. Very pleased with the lighting though I do use some task lighting for the lathe, drill press, and bench grinder.
Bill
-- bill@magraphics.us
View JayT's profile
JayT
5960 posts in 2412 days
#8 posted 01-12-2014 05:32 PM
T12’s are still being produced, but there had to be a change in the phosphors used (the white powder that glows under electric current, producing the light) and the CRI. The effects of that change are 1) new T12’s are not as quite as bright as previously and 2) they jumped dramatically in price.
The biggest difference, as Joe mentions is efficiency. Overall, T8’s use electricity about 25% more efficiently than T12’s, so you get a lot more light for the same energy or the same amount of light for less energy. Additionally, this efficiency allows lower heat levels in both the bulb and ballast, so T8’s last much longer—up to 40,000 hours in some commercial bulbs. The real key to the longer life, though, is degradation. All fluorescent bulbs become less efficient over their life, but the drop off for T8’s is much slower. For instance after 10,000 hours a T12 might only be putting out 65-75% of its original light, while a T8 will probably still be in the 85-90% range.
In general, switching from magnetic ballasted T12 fixtures to electronic ballasted T8’s will pay for itself in energy savings in around two years. Bulb replacement costs will also be much less, both because of price and longevity. Add the broader choice of light colors and T8 gives the most choices at the moment for good, efficient light.
T5’s are even more efficient, but pricing and readily available bulb options doesn’t make them feasible for most consumers, yet.
Color temperature is another area that you will want to address. These are measured in degrees Kelvin and basically the higher the number, the closer to color is to natural sunlight. Additionally, the higher the number the greater perceived light output, even though the actual lumen output doesn’t change. For a basic rundown.
2900K is soft white—a yellowish light that is easy on the eyes for tasks such as reading, but gives very poor results for determing color.
3500K & 4100K are considered to be cool white. These are the most frequently used color temperatures in office environment. 3500 is a bit more pink and 4100 more blue. Again these temps will not give accurate results for color.
5000K & higher are considerd to be daylight bulbs. 6500K is probably the closest to sunlight that is readily available. Color accuracy is excellent, but the light can be harsh on the eyes and tiring.
In an ideal world, I would have 4100K bulbs over my working areas as the best combination of light output vs eye strain and 6500K in the finishing areas so that colors are seen accurately.
I understand there is a lot of information to try and digest, I deal with it almost daily, but I would really recommend anyone switch to T8 when possible. It pays for itself in very short time.
tefinn
#9 posted 01-12-2014 05:33 PM
Joe – It’s very easy. All you need to do is cut the wires on the old ballast (after you turn the power off of course) and connect the wires to the new one using the diagram that comes with the ballast. Blk to Blk, Wht to Wht, One Blue to one tube end, the second Blue to one end of the second tube and Red to the opposite end of both tubes. The new ballast’s have no Yellow wire. Now each tube is wired independent of the other, so if one goes out or is removed, the other stays lit.
View bbc557ci's profile
bbc557ci
595 posts in 2275 days
#10 posted 01-12-2014 05:40 PM
Couple of weeks ago I finished putting up the lighting in my new shop/garage. 36’ x 26’ with 12 foot ceilings. I painted the entire inside a light colored antique white in semigloss, ceiling included. Then hung/screwed nine – 8 foot T-8 fixtures directly to the ceiling. Each of the nine fixtures takes 4 bulbs. Lighting in the shop is really great, seems just like being outside light wise. Plenty of fixtures/lights evenly distributed and the semi paint is great for light reflection so zip/nada for shadows :o)
Before addressing the lighting I had read here on LJs that T-12s would soon be or are/were getting phased out and or harder to buy. Building the shop got me about broke, so price was more of a consideration than the latest wiz bang in lighting. T-8 was cheaper than the T-5 so that’s the way I went. I’ m real happy with the results.
Just hope the progressives/socialists in our government don’t phase out the T-8s too soon ;o)
-- Bill, central NY...no where near the "big apple"
#11 posted 01-12-2014 06:00 PM
in my 30’x60’ old shop
i had 3 rows of lighting every 10’
alternate t-12 tubes and 300 watt incandescent pool table fixtures
each row switched independently
(i had read somewhere that tube lighting alone was not enough)
this was before Al Gore invented the internet
and at that time just regular tubes were available
(at least at the big box stores)
thanks everyone for clearing this up
JayT
you mentioned hd as a source for the ballasts to swith over to
do you have a code # or brand to look for there
TravisH
#12 posted 01-12-2014 06:01 PM
There are a lot of aspects that effect comparisons. You see the common ones from wood working sites mentioned here. Get into aquariums and you see a lot of other variables. I have some t5HO systems over my reef tanks that easily throw more usable light because of the reflectors, ballasts, and fans to cool the bulbs/ballasts than units from big box stores (would have to run more bulbs on the box stores) but we are in a totally different price ballgame with these units (550 for the fixture and mid 20s for a light bulb).
A lot depends on the shop size and how long you will have the lights on. My small shop we are talking chump change between the different lighting options. I like the highest CRI rated bulbs I can get. Currently running screw in flourescents over my work bench that are a 6500k “full spectrum”. Nice white crisp light with accurate color representation.
View JayT's profile
JayT
#13 posted 01-12-2014 06:18 PM
Actually, that was tefinn that mentioned HD. The company I work for is a competitor to them, so I definitely wouldn’t be buying at big orange :-)
Regardless, there are several manufacturers and all the models will be different. Any good hardware store or home center will have ballasts. All you need to know is how many bulbs and what length/size, the ballasts will be labelled that way. For instance, in Joe’s case, he just needs to find a ballast that is for 2 F96 bulbs and he is good to go. The new electronic ballasts are all rated for T8 or T12, and as tefinn mentioned, the ends are identical.
Edit: If you take the bulb information in to a store and they don’t know what you are talking about or can’t immediately help you find the right ballast, RUN, don’t walk, away and go somewhere where the staff in the electrical department actually has some training.
The most common configurations for T8 are either two or four bulb F32 fixtures, which use 4’ long bulbs and two F96 bulbs, which are 8’ long.
View TheDane's profile
TheDane
5549 posts in 3864 days
#14 posted 01-12-2014 06:30 PM
Lee—When I built my new shop in 2012, I had the electrician install T8 fixtures … 4 4-tube fixtures in the shop itself and 3 4-tube fixtures in the adjacent garage. We used the 5000K Full Spectrum bulbs. With bright white walls and ceilings they do a fine job.
TravisH
#15 posted 01-12-2014 06:34 PM
Amazing what some white paint will do. I painted some of the panels this last time and it made a difference for sure.
I have replaced several ballasts on fixtures with Fulham Work Horse Ballasts. Never had any complaints with them and they have about every possible wiring combination on the website if one wants to make sure.
