Any suggestions for finishing jigs made of MDF
Forum topic by WayneC posted 519 days ago 246 views 0 times favorited 11 replies Add to Favorites
View WayneC's profile
WayneC
5684 posts in 625 days
519 days ago
Topic tags/keywords: mdf finishing jig jigs
Something easy cheap and hopefully easy to find a the local big box store. Thanks.
View Steffen's profile
Steffen
233 posts in 563 days
519 days ago
My sled is made from MDF and the only thing I put on it is minwax. I only do the top, bottom and the slides (which are oak). I wish I had more suggestions for you.
Steffen
-- Steffen
View Damian Penney's profile
Damian Penney
726 posts in 519 days
519 days ago
I usually just slop on some poly or danish oil, just something to prevent glue sticking to it.
View mot's profile
mot
4851 posts in 564 days
519 days ago
I just seal it to paint it, and then only the edges. I mix some carpenters glue in water and paint it on. Other than that, what happens, happens. I hadn’t thought about poly or Danish oil as I figured it would just soak it up forever. Good tip, Damian. I’ll have to try it.
View Tony's profile
Tony
620 posts in 558 days
519 days ago
I just use 2 or 3 coats of paste wax-wait until each coat is fully dry, then buff until is shines.
Or, the second method I use is a general varnish, thinned with mineral spirit (30%) 12 hours between coats – 3 coats – after 3 weeks it is a really hard – long lasting finish.
It really does depend on the application – I never make my jigs look like works of art – they are normally a LOW TECH sollutions.
WayneC
519 days ago
Thanks, I was asking because I did the suck up poly forever trick on the edges of a commercial table saw sled (LOL, I own a Dubby, a story for another day). I’m planning to build the shooting boards on the Lie-Nielson web site and thought it would be nice to make them durable. I think may try the varnish method Tony suggests.
View David's profile
David
1830 posts in 667 days
519 days ago
I use two spray coats of shellac.
WayneC
519 days ago
Assuming your using your HLVP rig David. Hmmm another thing to add to the someday list. : ^ )
View Bill's profile
Bill
2524 posts in 689 days
519 days ago
Well you could just wipe on the shellac too. I don’t suppose that chalkboard paint would be a good thing to use? At least you could mark it up and not worry about it.
13165 posts in 928 days
519 days ago
I would think that you’d want something to soak into the fibers of the MDF and protect it. I’d think that Tony’s choice would do a great job.
View Bob Babcock's profile
Bob Babcock
1807 posts in 614 days
519 days ago
I agree karson…Tony’s sounds like a winner. I just bought some to make a couple jigs I need and I don’t want to make them twice.
View Jeff's profile
Jeff
967 posts in 622 days
519 days ago
Wayne, to add to Tony’s comment and others above. Matthew Teague mentions in his router table project in his Shop Projects book, to coat the MDF in Shellac and then a few coats of wax. I would imagine the wax would go on top of a coat of wax much easier than the bare surface of MDF. It sounds like a seal coat more or less. I offer this up not having done it myself but from the standpoint that it makes sense.
- Jeff
-- Jeff, St. Paul, MN
Bookmark And Share This Page
