Shellac - Flakes vs Canned?
Forum topic by gfadvm posted 01-12-2014 02:20 AM 4134 views 1 time favorited 43 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2654 days
01-12-2014 02:20 AM
What are the advantages to mixing your own shellac vs just buying the ready to use Zinsser Bullseye or Sealcoat?
43 replies so far
View DocSavage45's profile
DocSavage45
8519 posts in 2806 days
#1 posted 01-12-2014 02:25 AM
From a great review of finishes by Charles Neil. Shellac in can is suppose to last only about 6 months. You can mix flakes in any proportion you want and in as small an amount as you like.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Loren's profile
10253 posts in 3612 days
#2 posted 01-12-2014 02:28 AM
The Zinsser keeps for a couple of years from my observation.
Some finer shellacs are only available in flakes. For everyday
shellacking I use the stuff in the can as it’s a good cut of
shellac for the money and keeps ok.
View JL7's profile
JL7
8644 posts in 2929 days
#3 posted 01-12-2014 02:28 AM
Agree with Doc, buy the flakes and mix small batches….I wrap some black tape around the jar lid also…...
-- Jeff .... Minnesota, USA
View woodenwarrior's profile
woodenwarrior
226 posts in 2159 days
#4 posted 01-12-2014 02:29 AM
I like using Tiger Flake garnet shellac. I really think the finish is better with flake versus canned. It lays out smoother and buffs out easier than Zinsser does. The ability to mix your own in any cut and in any amount is a really nice benefit. In the end, flakes end up being cheaper than canned shellac.
-- Do or do not...there is no try - Master Yoda
View rance's profile
rance
4255 posts in 3124 days
#5 posted 01-12-2014 02:29 AM
You can also mix flakes to a thinner consistency which folks do sometimes for that first coat. That way it will soak in a bit more. And yes, the shelf life of mixed Shellac is short.
By the way, did you know that Shellac was made from the secretions from the female Lac bug? If it were from the male Lac bug, they would have called it Hellac.
View toddbeaulieu's profile
toddbeaulieu
814 posts in 2968 days
#6 posted 01-12-2014 02:29 AM
I’ve read similar,, but I don’t think it as that short of a period. Regardless, the concensus is that from the moment you add alcohol the shellac starts to degrade, so if you’re not turning it over quickly you should consider flakes.
You can thin premix just as easily, though.
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#7 posted 01-12-2014 02:32 AM
No advantage either way. Shellac is unnecessary.
View BuckI's profile
BuckI
49 posts in 3112 days
#8 posted 01-12-2014 02:38 AM
Where do you guys buy the shellac flakes from? I bought some flakes from Rockler and haven’t used them yet-thanks for any help.
-- Kevin, Ohio
toddbeaulieu
#9 posted 01-12-2014 02:44 AM
That’s where I’ve gotten mine so far. Be aware that that flakes also come in color and wax.
View dawsonbob's profile
dawsonbob
2818 posts in 1719 days
#10 posted 01-12-2014 02:47 AM
Does amber shellac come in de-waxed, too, or would you have to add some dye to get de-waxed back to an amber color?
-- Mistakes are what pave the road to perfection
gfadvm
#11 posted 01-12-2014 02:49 AM
Thanks for all the quick answers. I’ll look into the different flakes available. I really thought that being able to choose a color/tint would enter into this discussion?
What does garnet shellac look like?
View Lewis Landry's profile
Lewis Landry
13 posts in 1577 days
#12 posted 01-12-2014 02:50 AM
Here’s another tidbit about Zissner shallac… Yesterday I thought I smelled something all day while working in my shop. The smell just kept getting stronger as the day wore on. Late in the day I reached for a cabinet scraper and noticed something dripping from the cabinet. Yep, the Zissner Shallac (nearly full can) had sprung a leak. What a mess. MS wouldn’t touch it. Had to use Acetone for the clean up. This is the second time for me in a couple of years that a can of Zissner shellac broke out of its can. Had two cans. Both went into the garbage. Additionally, the shop is heated 24/7 so can’t blame freeze/thaw. Bye bye
Lewis Landry
#13 posted 01-12-2014 02:52 AM
#14 posted 01-12-2014 02:53 AM
FYI:
Zinsser is a 2 lb. cut generally. That’s 8 oz of shellac
to the quart.
When you figure in shipping on shellac flakes, it’s
not a bad deal since it can be got at hardware
stores easily. If you don’t use shellac often or
on larger pieces, mixing it from flakes can be
economical.
Denatured alcohol has a cost too. A gallon of
2lb. cut mix-it-yourself flake shellac is likely to
run $50 ($15 per lb shellac + $5 shipping, $15
gallon of alcohol) or more when you crunch the
numbers.
#15 posted 01-12-2014 02:57 AM
You can dewax shellac yourself but I don’t know how to
bleach it. The super-blonde grades are in the $30/lb
range (plus shipping) and the ambering of the work
is not too much. It looks and sounds great on spruce
guitar soundboards. The color is just slightly warm.
showing 1 through 15 of 43 replies
