Table Saw vibration
Forum topic by Woodworker101 posted 01-12-2014 12:48 AM 1002 views 0 times favorited 11 replies Add to Favorites Watch
View Woodworker101's profile
Woodworker101
22 posts in 1776 days
01-12-2014 12:48 AM
Hi Everyone,
I have had my table saw for a few months now and I have noticed a fair bit of vibration.
How can I minimize or eliminate the vibration of my table saw?
Many thanks.
-- Jackson, Australia,http://www.jacksonsfinecarpentry.com.au/
11 replies so far
View knotscott's profile
knotscott
7871 posts in 3279 days
#1 posted 01-12-2014 12:56 AM
It depends a lot on the type of saw…
Woodworker101
#2 posted 01-12-2014 01:23 AM
It is a 10” Carba Tec Contractors Saw
View Jimbo4's profile
Jimbo4
1600 posts in 2667 days
#3 posted 01-12-2014 01:45 AM
Link belt from HF can help. Saw blade not balanced?
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View BuckI's profile
BuckI
49 posts in 3052 days
#4 posted 01-12-2014 01:51 AM
I had a Delta contractors saw and a link belt on it did help with vibration, but I also got a set of turned pulleys from Rockler and that helped tremendously. Making sure the pulleys are in alignment with one another may also help.
-- Kevin, Ohio
View Biff's profile
Biff
126 posts in 1918 days
#5 posted 01-12-2014 02:11 AM
Start by trying a different blade.
-- Interested in Oregon property? Visit me at http://www.willamettepropertiesgroup.com
View CrazeeTxn's profile
CrazeeTxn
151 posts in 1854 days
#6 posted 01-12-2014 02:56 AM
I did the pulleys and link belt from HF and it passed the nickel test with flying colors. That includes, start up, running, and shutdown.
View Rick_M's profile
Rick_M
11101 posts in 2284 days
#7 posted 01-12-2014 09:16 AM
My Delta came with a machined pulley but still had a fair amount of vibration; after a link belt it’s like a new saw and nickels stand without a problem.
-- http://thewoodknack.blogspot.com/
View recycle1943's profile
recycle1943
1618 posts in 1526 days
#8 posted 01-12-2014 11:24 AM
I have a Sears 10” that is 25 years old. What vibration ?
-- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them
Woodworker101
#9 posted 01-12-2014 11:41 AM
It appears to be somewhere around the motor
knotscott
#10 posted 01-12-2014 12:03 PM
Assuming it’s a belt drive saw, there are a few things you can try. Check the alignment of the pulleys, check that the pulleys are tight on the shaft, and make sure they’re not damaged. As mentioned, you can try a different blade. You can remove the blade and belt to see if the vibration still exists….if it does, its something with the motor. If it goes away, it’s likely the belt or the blade. A different belt is often an easy and inexpensive cure….it’s not uncommon for a stock v-belt to take a set and cause vibration. A link belt or better v-belt is worth trying if the belt appears to be the cause.
Jimbo4
#11 posted 01-12-2014 06:08 PM
As for informational purposes – the green link belt at HF is made in Italy – NOT CHINA.
