Spindle chair repair
Forum topic by Elvin posted 01-11-2014 06:25 PM 1267 views 0 times favorited 7 replies Add to Favorites Watch
View Elvin's profile
Elvin
72 posts in 3423 days
01-11-2014 06:25 PM
Topic tags/keywords: chair repair spindles question
A friend asked if I could repair some of his chairs that have become loose over the years. I said I would research it and see if I was in over my head.
This is one of the chairs. It has eight spindles and loose seat legs.
Has anyone repaired a chair like this? Any suggestions? How long, on average , would it take? I am a one man shop and any help would be appreciated.
El
-- Elvin, Southern California, "How great would life be if we lived a little of it everyday"
7 replies so far
View wseand's profile
wseand
2796 posts in 3066 days
#1 posted 01-12-2014 02:39 AM
Could you give a little better idea of the problems with it. Loose spindle, cracked seat, etc.
I have used acetone to loosen up the glue and the spindles come out pretty easy. Then really it is just sanding the pieces and then glue them back in. If there is any broken spindle you may have to manufacture/purchase one. If part of the seat is cracked you can glue some Butterfly Keys across the crack. I have also used dowels to reinforce cracks.
I have had cracks in the rail, this is how I fixed that problem. HERE
wseand
#2 posted 01-12-2014 02:50 AM
As far as time, depends if your going to re-finish it and the extent of the damage.
Edit: Sorry I missed the first part of the question, I got loose spindles and seat.
View mtenterprises's profile
mtenterprises
933 posts in 2717 days
#3 posted 01-12-2014 04:34 AM
I’ve done LOTS of these over the years and once you are skilled in how these things are built it could take anywhere from a couple hours to oh maybe four hours to dissassemble and reglue one of these. Watch out for hidden pin nails they can make the job go real bad trying to get them out. If the joints come apart easily, great but if the don’t give any indication of looseness leave them together. Make sure all the old glue is removed from ALL surfaces to be reglued. Any regular hard drying wood glue works(hide glue, titebond, Elmer’s wood glue). Do not fill the sockets with glue but paint the sides of the sockets and the tenons, the glue does no good what so ever in the bottom of the hole. Assemble quickly so the glue doesn’t set because you often have to bend things into place and give them a bit of a twist. Once started in the gluing process don’t stop, don’t let people call you away from this part of the job. Then all I use to clamp most chairs is a loop of rope and a stick as a tourniquet to apply pressure all around. It can be done on the legs and backs both with a little thinking. When done properly these chairs are usually good for another 25 to 30 years.
MIKE
P.S. Oh yea number your joints on both parts so you get it back together correctly, believe me on this one.
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Picken5's profile
Picken5
255 posts in 2716 days
#4 posted 01-12-2014 04:51 AM
I agree with mtenterprises on this one. I’ve repaired a dozen or so of these type chairs. Assuming all the parts are in good condition, it’s not too hard to take it apart, clean the joints and glue it back together. I usually find it easier to glue the legs (with cross pieces) to the seat first. When that’s set up, I’ll work on the back with it’s spindles. (But, that strategy doesn’t work with some of the bentwood chairs where the back and rear legs are one piece.) Two to four hours is about right. Now, if you’re also refinishing, that’s another story altogether… and a lot more time.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
Elvin
#5 posted 01-12-2014 06:46 AM
Thanks to all of u for taking the time to respond. I can use all of your info and it has given me the confidence to work on these chairs.
mtenterprises
#6 posted 01-12-2014 01:09 PM
Believe it or not these chairs lend themselves well to repairs as long as nothing stupid has been done to them previously. Repair or replacement of broken parts is another story and often a judgement call as to what is best for the chair and the customer. That is how I first got into turning, because I could not find proper replacement parts. I have way too many tips and tricks to post here so if you run into any problems contact me.
Bill – Thanks for the acetone tip I think I’ll try that on my next repair.
MIKE
wseand
#7 posted 01-12-2014 02:29 PM
Mike,
Works like a charm for me
Great job explaining the process, I lack literary elegance.
El,
If you run into any problems along the way don’t hesitate to ask for some help. I’m sure you’ll do fine.
