Help with locating belt for table saw
Forum topic by flwoodhacker posted 01-11-2014 02:05 PM 2982 views 0 times favorited 8 replies Add to Favorites Watch
View flwoodhacker's profile
flwoodhacker
58 posts in 3127 days
01-11-2014 02:05 PM
Topic tags/keywords: tablesaw parts
Good morning. Need some guidence to locate a source for a timing belt for a Jet JWSS-10LFR Left Tilting 10” SuperSaw.
The belt is part of the mechanics in raising and lowering the saw blade. I called Jet and the part is discontinued. The CSR offered some suggestions but they did not pan out.
I looked at the manual (http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000042207.pdf) and it has the part listed as such: 993101 – Timing Belt – 369-3GT-10MM
It’s pretty Greek to me. If you have any sourcing or other suggestions please let me know. The saw is pretty useless without being able to raise and lower the blade.
Many thanks in advance.
8 replies so far
View Ted78's profile
Ted78
401 posts in 2201 days
#1 posted 01-11-2014 02:29 PM
http://www.ereplacementparts.com/timing-belt-p-544597.html
with the right part number you might be able to get the same thing a lot cheaper at an auto parts store.
-- Ted
View JustJoe's profile
JustJoe
1554 posts in 2240 days
#2 posted 01-11-2014 02:43 PM
These guys say they have it, but that it is special order so ask them to ask Jet if there are any left.
http://www.ereplacementparts.com/timing-belt-p-451040.html
If not, you need to decipher your belt. The info is in here:
369-3GT-10MM
3GT is the type of belt.
10mm is the width – check your broken one and it should be close to .4” wide if this is correct.
The 369 is probably length but you need to determine how. It could be 36.9”, 369mm, probably not 36.9 miles etc.
When you’ve got the length figured out correctly you just hit google and start emailing one belt seller after another.
Belt Palace sells belts, but I don’t know if they sell 3GT style.
Gates
MiSumi
Brecoflex.
If the length is in mm, and you have any wiggle-room for adjusting, then a 370 might work as well as a 369. And if any of those makers above don’t sell it, one or more might make custom length belts for you.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
5176 posts in 2695 days
#3 posted 01-11-2014 02:44 PM
Look carefully at the old belt. These belts are all purchased from belt manufacturers, and 99% of them are a stock item. If you see any numbers at all on the belt, you may be able to search that and find the factory equivalent.
Edit: justjoe posted the pertinent info while I was typing. Belt Palace is a great place for these, or an industrial supply like Graingers.
View Bluepine38's profile
Bluepine38
3379 posts in 3287 days
#4 posted 01-11-2014 05:59 PM
If you can find the numbers on the belt, and hopefully a manufacturers name, then an auto parts house
might be able to either sell you the same belt or use a cross reference chart to get an identical one from
another manufacturer.
View JoeinGa's profile
JoeinGa
7739 posts in 2209 days
#5 posted 01-11-2014 07:02 PM
Is that a “V” belt? or a “toothed” belt? Any chance one of those link belts would work?
View darthford's profile
darthford
612 posts in 2126 days
#6 posted 01-11-2014 07:08 PM
NAPA Auto Parts is great at cross referencing belts, they had belts for my Grizzly gunsmithing lathe in stock.
flwoodhacker
#7 posted 01-12-2014 01:51 PM
Seems I came to the right place to find information. Thank all of you for your response.
flwoodhacker
#8 posted 01-15-2014 02:41 AM
Just to offer an update I located a manufacturer, Michigan Industrial Belting (http://www.mibelting.com/). They were able to make a belt for my saw. Awesome customer service. Saw is up an running!
