Quarter Sawn White Oak with Oak Plywood
Forum topic by Core2 posted 01-11-2014 05:42 AM 2344 views 0 times favorited 7 replies Add to Favorites Watch
View Core2's profile
Core2
60 posts in 1568 days
01-11-2014 05:42 AM
Topic tags/keywords: question oak
If I do a frame and panel, with the frame being Quarter Sawn White Oak, and the Panel being oak plywood wood how would that look? Has anyone used these together?
The Plywood won’t be anything special. Just oak plywood from Lowe’s.
7 replies so far
View Woodmaster1's profile
Woodmaster1
918 posts in 2550 days
#1 posted 01-11-2014 06:43 AM
I would try to find quartersawn oak plywood. I see your in the Midwest, Menards sells it by special order or try to find a hardwood dealer that has it. I buy mine from ll Johnson’s lumber . Menards has it at a better price.
View jumbojack's profile
jumbojack
1674 posts in 2587 days
#2 posted 01-11-2014 06:43 AM
It is done all the time. It will look great, if you like oak, that is.
View madts's profile
madts
1855 posts in 2302 days
#3 posted 01-11-2014 08:20 AM
Yes try to get the quarter sawn plywood. Too me it wood look a whole lot better.
-- Thor and Odin are still the greatest of Gods.
4945 posts in 2456 days
#4 posted 01-11-2014 04:26 PM
I don’t particularly care for the cathedral grain look of plain sawn oak, besides which most oak plywood at the box stores has a red oak veneer which could have a different color in the finished piece. I would (and do) use quartersawn oak. Without knowing exactly where you are, you could try Menard’s; that might be the easiest. Be aware, that will probably be special order, and they stick a pretty stiff “packing” charge on it. Or try to find a Columbia Forest Products dealer nearby and ask for it there. Good hardwood lumber dealer’s sometimes stock it as well.
View Beard's profile
Beard
22 posts in 1577 days
#5 posted 01-11-2014 04:53 PM
I built Norms tall clock out of quarter sawn white oak not sure the size of your panel but, I glued up two quarter sawn boards and milled them to 1/4 they looked real good I will post the clock soon.
I did build a gun cabinet the bottom three draws were quarter sawn white oak and the plywood case was red oak it turned out good. I used golden oak from minwax. I would take some scrap and test the finish you will be using.
The back of the clock was quarter sawn white oak in VA a 1/4 sheet was almost 80.00
-- Beard,Bristow Virginia
404 - Not Found
2544 posts in 2932 days
#6 posted 01-11-2014 05:32 PM
This might not be very helpful to you, but any veneered sheets (mdf) we get over here are usually crown one side and quarter sawn on the other, the best of both worlds. As for mixing solid wood with veneered sheets, it’s done all the time and usually both finish the same.
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3327 days
#7 posted 01-11-2014 05:47 PM
If you don’t want to go for QSWO plywood, try to use the more straight grained parts (rift) of the oak plywood for your panels. Rift with qs would make an appealing looking panel. As Renners mention, there is the veneer panel option. I have made my own QS panels using oak veneer from Rockler (24” x 96” Pressure Sensitive Veneer – White Oak (Quarter Sliced) Item #: 61332). Avoid rotary cut plywood since the grain pattern is wild and unnatural.
