Counter or Shelf over Washer/Dryer
Forum topic by DavidATX posted 01-10-2014 11:24 PM 6327 views 0 times favorited 3 replies Add to Favorites Watch
View DavidATX's profile
DavidATX
25 posts in 2041 days
01-10-2014 11:24 PM
Something like this?
I am going to build a shelf/counter over a washer and dryer and my question is will 3/4 plywood bow? The plywood would be about 6 ft long and 2 1/2 deep (depth of washer/dryer) I was thinking of adding a piece vertically right in between the washer/dryer that comes out about 18 inches so it is not as visible from the front for support. Do you think that is sufficient?
3 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2278 days
#1 posted 01-11-2014 12:06 AM
How about moving the shelf up 1.5”.
Run a 1/2” ledger board along the back wall and the two sides for it to sit on.
Attach a piece of hardwood edging 3/4”x1-1/2 along the front edge, with 1-1/2” being the up/down thickness. That creates a lip on the front of the 3/4” plywood, gives the illusion of mass, and provides a means of stiffening the front. That, along with the ledger-board in the back, should keep it from sagging side/side.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View wseand's profile
wseand
2796 posts in 3281 days
#2 posted 01-11-2014 01:01 AM
The Sagulator. HERE
It’s a Online Calc. that computes sag. Best Damn Calc Ever.
I use it for Bookshelves, Cabinets, Etc….
wseand
#3 posted 01-11-2014 01:14 AM
I would put at least a 2-1/4” edging strip/skirt around the entire shelf and one down the center. That’s a lot of surface and someone might decide to put something heavy on it. I would make the skirt out of pine, 1X material not the Plywood.
