Lancelot & Squire Wood Shaping Tools
« back to Hand Tools forum
Forum topic by Rebarn posted 01-10-2014 06:46 PM 1898 views 0 times favorited 17 replies Add to Favorites Watch
View Rebarn's profile
Rebarn
204 posts in 1842 days
01-10-2014 06:46 PM
Any of you wood workers use the Lancelot/Squire system from King Arthur’s tools? Considering them for purchase and would appreciate some feed back if possible.
Cheers
Mark
-- A day without slivers is a day without sunshine!
17 replies so far
View CharlesNeil's profile
CharlesNeil
2470 posts in 4111 days
#1 posted 01-10-2014 07:56 PM
I have them .. actually about all of them.. they are excellent ..however the Lancelot chain saw cutters are pretty agressive .. as well as the Holey Gallads .. but they do a nice job .. Just be careful and take some time to get used to them,,,, They can be dangerous. A heavy apron and gloves is a must, I have a heavy leather apron and heavy leather welders gloves I use.
Rebarn
#2 posted 01-10-2014 07:59 PM
Hey Charles
Thanks man. I’ve seen the videos and they look awesome for what I need them for. I am a little concerned about the RPMs for sure. And I would say the tool will always demand respect due to the danger factor.
View Loren's profile
10477 posts in 3889 days
#3 posted 01-10-2014 08:25 PM
I have one of the ones with carbide teeth. It’s pretty scary
but it cuts predictably as I recall. I think it might be worth
considering adding some sort of apparatus to the angle grinder
to be able to control the carver with more distance between
the blade and one’s hands.
View SuperCubber's profile
SuperCubber
1048 posts in 2525 days
#4 posted 01-10-2014 09:59 PM
Here is what happens if you don’t respect the Lancelot: http://www.spswoodturners.org/carving-accident
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
Rebarn
#5 posted 01-10-2014 11:54 PM
Holy sh**!!
View blackcherry's profile
blackcherry
3338 posts in 4064 days
#6 posted 01-11-2014 12:02 AM
Sir Lancelot not for me…oh brother that just not fair!
Rebarn
#7 posted 01-11-2014 12:23 AM
I’m getting the system anyway. I’m just going to treat it as the most dangerous tool in the shop and wear protective gear. Also..full attention on the task.
Rebarn
#8 posted 01-11-2014 12:24 AM
People get brutalized with tools every day. The guy in the story was negligent.
View redryder's profile
redryder
2393 posts in 3343 days
#9 posted 01-11-2014 01:02 AM
I own one of these and have used it many times. When I first took the disks out of the packages and put them on the grinder it was obvious that this tool was no different than my chain saw. Like the chain saw, read the instructions, use two hands and make sure your work is firmly planted and it is no more dangerous than a table saw, drill press or bandsaw.
The one thing I did learn right away was how fast it works and how much of a mess it will make in the shop. It’s an outside toy for me….....................
-- mike...............
View Tim's profile
Tim
3812 posts in 2202 days
#10 posted 01-11-2014 01:20 AM
Is it possible to run these on a 7” angle grinder since they have a lower RPM? Putting these wheels made for a 4-1/2” grinder on a 7” grinder would mean the guard would probably need to be replaced but that’s about all I can think.
I agree the guy in the story was totally negligent. Still not sure you’d catch me using one of these. Maybe though, sure would be fun.
View Raftermonkey's profile
Raftermonkey
560 posts in 3153 days
#11 posted 01-11-2014 01:22 AM
I use the the Lancelot, Galahad’s, Merlin and Guinevere almost everyday. I’ve been using the Lancelot for 3-4 years and (knock on wood) I still have all ten fingers. It was pretty intimidating the first coupla times I used it but so far so good. It does take a firm grip but you don’t have to choke the handles out or stiff arm it or anything. However, if carving deep it will try to “ride up” the wall of what you’re carving. As far as the mess goes, yeah you’re gonna want to invest in an apron, glasses/shield and gloves are optional for me depending on what I’m carving. You’ll also need a good broom and dust pan. Also, invest in the universal nut and wrench if you’re getting a carbide wheel, otherwise you’re likely to break the burs off trying to use your standard wrench. (Happened to me once) other than that, have fun…..and carve with your mouth shut.
-- -Zeke- "I hate to rush off, but I gotta go see a man about a log"
Raftermonkey
#12 posted 01-11-2014 01:38 AM
Tim If it’s got a 5/8” arbor it will fit but I don’t see any advantage whatsoever in slowing the disc down.
View basswood's profile
basswood
261 posts in 1861 days
#13 posted 01-11-2014 01:40 AM
View oldnovice's profile
oldnovice
7380 posts in 3609 days
#14 posted 01-11-2014 03:36 AM
Aren’t there some less aggressive version of this carver available or am I mistaken?
basswood
#15 posted 01-11-2014 03:45 AM
It won’t do what the lancelot will, but I frequently use two 36 grit sanding disks back to back on a grinder. It is dusty, so best used with a some kind or down draft set up.
Here is a video I made a few years ago, coping 6-1/2” maple crown with a grinder. It takes about a minute to watch.
https://www.youtube.com/watch?v=EijqMNYBsLg
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
