Bandsaw Blade Assortment?
Forum topic by Dan Corbin posted 01-09-2014 06:39 PM 1249 views 1 time favorited 9 replies Add to Favorites Watch
View Dan Corbin's profile
Dan Corbin
57 posts in 2191 days
01-09-2014 06:39 PM
Topic tags/keywords: question bandsaw blade
What bandsaw blade(s) do you use? Width, thickness, tooth-per-inch (TPI), and tooth style? And what do you use each blade for?
I just recently got a new bandsaw (a Rikon 10-325) so I have been looking at new blades for it. I want to be able to do just about everything on it, but I am absolutely daunted by how many different combinations there are out there! So I thought that maybe you guys could chime in with your thoughts!
For resawing, I am seeing that a 3/4” wide 3 TPI blade seems to be pretty standard (the only thing I wish this bandsaw could do is accept a 1” wide blade). And I’m guessing that a 1/8” wide, 1/4” wide, and 1/2” wide blade would be beneficial, but I have no idea how many TPI to get in those.
Thanks!
-- ~ Dan, North Carolina, http://www.facebook.com/torahanjyuu/
9 replies so far
View CharlesA's profile
CharlesA
3330 posts in 1827 days
#1 posted 01-09-2014 07:10 PM
I just ordered a 1/2” woodslicer blade from highland woodworking for resawing. On their resawing tutorial PDF Guide Highland Woodworking recommends against a 3/4” blade for resawig.
View patcollins's profile
patcollins
1685 posts in 2894 days
#2 posted 01-09-2014 07:19 PM
Sometimes you just can’t get enough tension on the really wide blades, ie a 1 inch blade requires twice as much force to have the proper tension as a half inch blade does.
I think the rule of thumb is you want atleast 2 to 3 teeth in the wood at any one time to get a decent cut.
View mnguy's profile
mnguy
193 posts in 3427 days
#3 posted 01-09-2014 07:23 PM
I have the 1/2” Woodslicer on my Jet 14” saw, and it does a fantastic job; clean cuts, very little drift. For my 3/4 HP saw, I think the extra drag of a 3/4” blade could be an issue. The 1/2” works great.
View wncguy's profile
wncguy
395 posts in 2341 days
#4 posted 01-09-2014 08:20 PM
Dan – makes a lot of difference on blade choice depending on what you are doing. I also have the 10-325.
For example I am using a 3/16” 4 tpi skip from Iturra Design for my bandsaw boxes. Works much better than higher tooth count for boxes about 5” thick.
Louis Iturra told me that the 1/4” is kind of a standard blade for a lot of people (not for resawing).
Don’t know how much I’d use a 1/8” since I also use the Carter Stabilizer for my tighter curves.
We’re not that far from you… just north of Asheville.
-- Any man can be a father, but it takes someone special to be a Dad
View Woodbum's profile
Woodbum
813 posts in 3094 days
#5 posted 01-09-2014 08:47 PM
Depends on the application
Resawing-Woodslicer 1/2” blade from Highland Hardware
All purpose 1/8, 1/4, 3/8 or 1/2” Olson MVP or All Pro depending on the smallest radii to be cut.
-- "Now I'm just another old guy wearing funny clothes"
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#6 posted 01-09-2014 09:47 PM
I have the same saw and carry the following:
2×1/2” woodslicer resaw blades for – resawing (duh!)
2×1/8” tight curves blade (also from highlandwoodworking) for well… tight curves.
the saw should be adequate to handle a 3/4” blade from a power perspective. the reason many shy away from 3/4” blades on 14” saws is not the power- but the smaller wheel diameter which causes the blades to bend beyond their intended purpose. so it’s the blade that is the culprit and not the saw/motor.
I hear also good things about the timberwolf resaw 3/4” blades which supposedly are installed with a lower tension then normal blades so the above limitation might be less significant and could be doable resulting in a more true cut (no personal experience though)
View Bill White's profile
Bill White
4950 posts in 3989 days
#7 posted 01-09-2014 10:04 PM
I use: 1/4” 8 tpi., 3/8” 6 tpi, and 1/2” 3 tpi for most work.
I fortunate to have a BS blade supplier locally.
I have used the Woodslicer in the past with good results. The combo tooth config. is good.
Bill
-- bill@magraphics.us
View Surfside's profile
Surfside
3389 posts in 2202 days
#8 posted 01-09-2014 10:24 PM
“The general rule is that fewer teeth per inch provide a faster, but rougher cut; and more teeth per inch provide a smoother, but slower cut.” I would use 6TPI blade for 1/2” thick wood.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View nwbusa's profile
nwbusa
1021 posts in 2315 days
#9 posted 01-09-2014 11:04 PM
95% of the time! I have a 1/2” 3 tpi blade installed, for light duty resawing and general bandsaw work. If I am going to be doing a lot of resawing on wider boards, I’ll switch out to a wider blade. I also have some narrow blades (i.e. 1/4” 6 tpi) on hand for scrolling, which I don’t do much of.
-- John, BC, Canada
