Band saw, Snodgrass/Carter set up.
Forum topic by madts posted 01-09-2014 12:05 AM 838 views 2 times favorited 4 replies Add to Favorites Watch
View madts's profile
madts
1862 posts in 2335 days
01-09-2014 12:05 AM
I watched the video and was awed. Went out and tried the setup that was suggested. Cleaned the saw, did the adjustments and viola. The best sawing I have ever done. No nothing, no drift , just straight cuts. Just try it and you will be amazed.
http://www.youtube.com/watch?v=wGbZqWac0jU
The video is 35 minutes long but worth it.
-- Thor and Odin are still the greatest of Gods.
View cutworm's profile
cutworm
1075 posts in 2789 days
#1 posted 01-09-2014 01:40 AM
That dude is really good. Did he warn you about trying to slice a ham?? I still laugh when I think about your post.
Great video.
-- Steve - "Never Give Up"
madts
#2 posted 01-09-2014 04:15 AM
Unfortunately he did not mention ham.
View jmartel's profile
jmartel
7882 posts in 2145 days
#3 posted 01-09-2014 04:16 AM
I used the video to set up my Grizzly saw after I pulled it out of the box and put the extension block on it. Perfectly straight cuts immediately, including being able to pull off a 1/16” veneer piece from some walnut. I was quite pleased.
View Chris208's profile
Chris208
239 posts in 2265 days
#4 posted 01-09-2014 04:45 PM
I use this method after watching the video. My ‘94 14” delta is perfect when set up this way.
I can slice 1/16th inch veneers that are of consistent thickness from a 8 foot board.
No drift at all with a sharp blade.
I couldn’t recommend this video any more than I do.
