Koa table top trouble
Forum topic by DanFinn posted 01-08-2014 04:58 PM 1186 views 0 times favorited 6 replies Add to Favorites Watch
View DanFinn's profile
DanFinn
5 posts in 1838 days
01-08-2014 04:58 PM
Topic tags/keywords: koa penofin finishing trouble
Hello everyone,
I am having trouble finishing a Koa coffee table top. I will tell you what I did and let you know where the problems started.
Sanded from grits 60 to 80 to 150 to 220
then applied penofin interior penetrating oil (wiped on, let sit 15-20, remover excess/wipe off). Then I let it sit over night (about 13-15 hrs). Next I wet sanded with the penofin oil with 600 and then 1500 . Wiped off oil and recoated with fresh oil and let sit for 15-20 and wiped off. I immediately noticed that the darker grain had a cloudy and slightly gray hue. Let sit overnight to see if it cleared with curing. No.
So this morning I tried sanding back down to 150, then wiped with mineral spirits, let dry, and applied another coat of penofin. It still looks like there is a cloudy gray hue in the dark grain. I’m thinking I should not have wet sanded with the penofin.
What is the problem and how do I remedy it? (my current plan is to let cure for 3-4 days and if no improvement sand to bare wood and start over without the wet sand).
Thanks for your help everyone
Dan
DanFinn
#1 posted 01-09-2014 02:38 AM
Also, it says on the can of penofin that it can be wet sanded like that. Maybe too fine a grit and abrasives worked into grain?
View KayBee's profile
KayBee
1083 posts in 3483 days
#2 posted 01-09-2014 03:08 AM
The only time I worked with koa, it was finished with lacquer. Sorry that doesn’t rally help. Maybe let it sit for 2-4 days before doing anything. Oil finished can take forever to dry.
-- Karen - a little bit of stupid goes a long way
DanFinn
#3 posted 01-09-2014 10:11 PM
I’m going to let it sit until monday and see how it looks.
View ScrubPlane's profile
ScrubPlane
190 posts in 2433 days
#4 posted 01-09-2014 11:31 PM
I love working with Koa and cringe when I see problems with this awesome and expensive wood.
What was the humidity like the day you applied your finish?
View Danpaddles's profile
Danpaddles
573 posts in 2549 days
#5 posted 01-09-2014 11:35 PM
Monday may even be too soon. What was the age of the oil you used? I’d say, wait wait wait. Then, next time, try a different finish!
-- Dan V. in Indy
DanFinn
#6 posted 01-10-2014 08:16 AM
@ ScrubPlane: I don’t know if you live here on the big island, but it was about 4/5 days ago when that big storm was rolling in, so it was up there.
@Danpaddles: I am thinking about waiting until i can wipe without oil coming off (to a reasonable degree). Also, it was a brand new can, just opened for table top.
