circle cutting bits
Forum topic by lunn posted 01-06-2014 12:48 PM 1019 views 0 times favorited 4 replies Add to Favorites Watch
View lunn's profile
215 posts in 2239 days
01-06-2014 12:48 PM
I’ve had 2 circle cutting bits in a box of stuff for almost 2 years i bought at a auction . I used the small one for the first time Saturday. One cuts up to 6 in the other 12in. adjustable. Almost the same as the Rockler #42887. Although almost impossible to get a percise hole, these things work GREAT. No more fighting with a hole saw, getting the plug out, smoke etc. plus a very clean hole. The only down side is safety. The arm sticking out at 600 rpm could get your hand. Anyone else use them?
-- What started as a hobbie is now a full time JOB!
View Danpaddles's profile
573 posts in 2243 days
#1 posted 01-06-2014 01:11 PM
As the diameter of your hole gets bigger, that single tooth has to cover more ground. Even at 600 RPM, that single point is doing a LOT of work. Keep your dust out of the cut, watch for burning. Keep that point sharp. And watch out when you touch it!
-- Dan V. in Indy
View Gene Howe's profile
Gene Howe
10250 posts in 3359 days
#2 posted 01-06-2014 01:19 PM
Ditto Dan.
I’ve used them, I do not like them. But, sometimes, they are the best way to go, especially if the hole is an odd size.
Paint about an inch of the end of the arm with a fluorescent orange paint. It won’t hurt any less, but you’ll be able to see it coming. Seriously, it does make you more aware of the spinning arm.
View hydro's profile
208 posts in 1682 days
#3 posted 01-06-2014 01:46 PM
I use mine fairly often and it works great. A little scary the first time you spin it up but just be careful.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
View b2rtch's profile
4851 posts in 2979 days
#4 posted 01-06-2014 01:54 PM
It was a big debate in the reviews section about these things a while ago , someone almost got hurt with one of those ( but a HF. he/she did not know how to safely use it).
I have used one one safely for many years (a HF style) and I find it very useful.
-- Bert
