orange peel
Forum topic by oldwoodsale posted 01-05-2014 10:42 PM 2062 views 0 times favorited 2 replies Add to Favorites Watch
View oldwoodsale's profile
oldwoodsale
21 posts in 3214 days
01-05-2014 10:42 PM
Having a problem with orange peel in clear gloss minwax polyurethane and Hellman’s urethane. Both are in spray cans. I have used each of these products before and got a mirror smooth finish. I started with the minwax and first coat it was minor. Let it dry 3days, gave it a light sand and recoated. OP was bad. I sanded it off, re-sprayed real wet and again bad OP. Sanded again to a nice flat surface. This time I used Helman’s and I waited till it was just set up enough for 2nd heavy coat. The OP worse than ever. I though OP was due too light a coat. I have followed my past practice (and the can’s instructions) perfectly and can’t understand this. Any help would be appreciated.
2 replies so far
View Pezking7p's profile
Pezking7p
3230 posts in 1891 days
#1 posted 01-05-2014 10:59 PM
Orange peel is a drying or a wetting defect. Since you experienced this with two different finishes, I’m going to rule out a wetting problem. Also because it was worse when you added a second coat soon after the first, I’m going to suggest that it’s too cold where you are applying it. Needs to be warmer or you need to apply a lighter coat. Or switch to something with higher solids content like a wiping poly. Good luck.
-- -Dan
View Tkf's profile
Tkf
38 posts in 2167 days
#2 posted 01-06-2014 01:02 AM
Orange peel can happen for three reasons:
Temperature – Too cold will prevent the finish from flowing and leving out.
Pressure and needle issues – no concern here.
Too thick – again levelling put issues.
And there is orange peel in every spray finish. You just can’t see it if you don’t have a trained eye. You can continue applying more finish, letting it cure and then polishing it. But that is more labor and time intensive.
