dining chair construction and upholstery help
Forum topic by scottishbob posted 01-05-2014 09:23 PM 1204 views 0 times favorited 6 replies Add to Favorites Watch
View scottishbob's profile
scottishbob
171 posts in 2405 days
01-05-2014 09:23 PM
Hi guys
Can anyone help me with the construction of the back of this chair and best how to fit/attach the upholstery panel.
I have been searching for a elegant dining chair for some time now and my wife is set on these ones, which are very expensive.
I just want to get to grips on how best to go about it before i breakout any timber or start making jigs/templates.
The back panel looks to be fitted flush with the back legs, but i reckon you would see the edge on the side of the back legs which wont look very nice ! I was thinking i should insert the back into a groove in the legs and top rail (that maybe a bit easier)?. but really stuck on how to insert the upholstered panel. If anyone has any tips on upholstery that would be appreciated also .
Thanks
-- Ireland, Galway .... fingers! "we dont sell them"
View Loren's profile
10477 posts in 3765 days
#1 posted 01-05-2014 09:51 PM
Velcro. Snaps.
View sras's profile
sras
4872 posts in 3247 days
#2 posted 01-05-2014 10:04 PM
As Loren says, Velcro or snaps would work and give you a way to re-upholster later on. Velcro might gie way as time goes on. The trick with snaps might be getting good alignment.
Are you planning to make 5 separate panels? That might be easier than one curved one…
#3 posted 01-05-2014 10:15 PM
You can buy higher grade velcro. I’ve used some stuff that
grabs real securely. It is used to attach grills to loudspeakers
often enough. Check out some guitar amplifiers in a
music store and you’ll probably find that a little bit of
the good Velcro is pretty sticky.
I would rabbet the front, drop a veneered back panel in
there and screw it down, then put the Velcro on that.
View oldnovice's profile
oldnovice
7124 posts in 3485 days
#4 posted 01-06-2014 05:54 AM
I’ll give you the same cushy answer ... so I go with industrial strength Velcro.
I have some of that 2” wide and it is strong.
I recovered some bar stools but there I had the previous panels to staple into.
scottishbob
#5 posted 01-06-2014 08:53 PM
thanks guys @ loren, like that idea for the rabbet
cheers bob
View Rob Vicelli's profile
Rob Vicelli
104 posts in 2809 days
#6 posted 01-14-2014 01:36 PM
Hi, When I made new chairs, for the seats I recessed them into rabbit I cut in to the chair frame. I currently do not have them fastened into the chairs, Just a friction fit. I have never had one come loose…..but we are sitting on them. Maybe a combination of friction fit and a few dabs of hot glue. I am sure that will be a challenging project, good luck.
-- Rob V
