Plane blade not adjusting
« back to Hand Tools forum
Forum topic by fredd3039 posted 01-05-2014 04:38 PM 941 views 0 times favorited 2 replies Add to Favorites Watch
View fredd3039's profile
fredd3039
14 posts in 2232 days
01-05-2014 04:38 PM
Hello all,
I have a question about lever cap screws and their proper tightness. I have a Lie Neilson no.4 and I cant get the blade to adjust properly. It moves a little, and I mean a little but the adjuster knob locks up tight. How tight should the lever cap screw be? After I sharpened the blade I put everything back together and maybe I tightened the screw down to tight. I need a good source of information on how to properly set up the plane after taking it apart.
Any help?
Frank
2 replies so far
View jmos's profile
jmos
843 posts in 2423 days
#1 posted 01-05-2014 05:24 PM
The rule of thumb (pun intended) I’ve heard is that the cap lever should be stiff, but you shouldn’t have to hurt your thumb snapping it. Too tight and it will make adjustments difficult. Too loose and the blade can shift or chatter. I’d play with tension and see if it helps your issue. On a new LN, you shouldn’t have any issues. If you think it’s a plane problem, give them a call.
Also, don’t tighten the screw after you’ve snapped the cap; adjust the screw then snap it. Much easier to tell how tight it is.
-- John
View Tim's profile
Tim
3812 posts in 2015 days
#2 posted 01-05-2014 07:18 PM
How tight should the lever cap screw be? Not that tight. Tight enough that the blade doesn’t move on it’s own, but loose enough that you can adjust it with the depth adjuster and lateral if the plane has one.
Lie Nielsen has some very good youtube videos and in many of them they’ll even suggest a certain number of turns of the screw, say a quarter turn to give the tension you need.
