Question about 220V
Forum topic by Jesse posted 01-05-2014 04:24 PM 1108 views 0 times favorited 14 replies Add to Favorites Watch
View Jesse's profile
Jesse
58 posts in 1530 days
01-05-2014 04:24 PM
I am moving into my new shop soon and I need to run a 220 outlet for my dust collection system. Normally it is no problem, I know how to run basic wiring and 110 and 220/240 outlets safely. However, this panel does not seem to have a main breaker to shut off power to the entire panel. Is that possible? If so, is there a shut off outside at the meter perhaps or something like that I should be looking for. If not, is there a safe way to install the breaker while the panel itself is hot or no? This is not a residence, it used to be a auto mechanics building before I got my hands on it.
14 replies so far
View mahdee's profile
mahdee
3843 posts in 1671 days
#1 posted 01-05-2014 04:27 PM
Every panel has a shot off. Normally on the top with two switches attached to each other. If you have an outside panel, same thing.
-- earthartandfoods.com
View teejk's profile
teejk
1215 posts in 2588 days
#2 posted 01-05-2014 04:43 PM
If it’s a sub-panel, the shut-off should be on the main feeder panel. In many cases the sub is supposed to have its own kill switch but it doesn’t always happen.
View bbc557ci's profile
bbc557ci
595 posts in 1978 days
#3 posted 01-05-2014 04:45 PM
What mrjinx said….there’s gotta be a shut off somewhere on a panel/service. Yes, you can remove and install breakers when the panel is hot and you can run/connect new 220V when the panel is hot. But I wouldn’t advise it. If I were in your position and not able to locate a shut off, I’d call an electrician to look things over. Regardless, you should know how/where to kill the power to the building if/when it becomes necessary…. JMHO
-- Bill, central NY...no where near the "big apple"
mahdee
#4 posted 01-05-2014 05:59 PM
If you haven’t found it yet, take a picture.
View Grumpymike's profile
Grumpymike
2214 posts in 2219 days
#5 posted 01-05-2014 06:24 PM
Like bbc said … “Yes, you can remove and install breakers when the panel is hot and you can run/connect new 220V when the panel is hot. But I wouldn’t advise it.”
More people are killed every year with 220v. than any other power source
Please! Consult with or hire a licensed electrician before you kill yourself.
Looking forward to seeing you on this site again.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View Bluepine38's profile
Bluepine38
3379 posts in 2989 days
#6 posted 01-05-2014 06:54 PM
There were a lot of old panels installed that did not have a main shut off, the power came directly from a
meter box that usually did have a shut off. The new boxes thankfully do come with main shut offs that
are also breakers that give you a backup just in case a regular breaker manages to weld itself in a closed
position.
teejk
#7 posted 01-05-2014 06:55 PM
Wiring live is possible. The new circuit is harmless until connected to the bus-bar but the problem is hooking in the neutral/ground wires with live power all around and the lack of non-conductive screw-drivers…one slip and you’ll learn how to weld. If I remember correctly a separate disconnect is not required on a sub panel if it is within a reasonable distance and in the same building as the feeder panel.
TopamaxSurvivor
18189 posts in 3579 days
#8 posted 01-05-2014 07:21 PM
Older panels installed prior to the single main code change about 1980 or a few years later will be what are known as split buss panel. They have an area at the top with room for a maximum of 6 – 2 pole breakers. One or 2 of those will feed a section or 2 lower in the panel where the 15 and 20 amp single pole breakers will be installed. The mains that feed the lower section will be 60 amps maximum. The top section with the mains will normally have the range, dryer and heating circuits. That top section is hot all the time and does not have a main to disconnect it.
TopamaxSurvivor
#9 posted 01-05-2014 08:46 PM
As an afterthought; I have been an electrician for over 45 years. If the panel is a Zinsco or FPE, I would not try to change a breaker in it while it is hot.
Jesse
#10 posted 01-05-2014 10:58 PM
Thanks everyone, I did some exploring around the outside of the building and found a shutoff for my bay at the meter. It looks like 4 breakers in one kind of deal but it killed the power to my part of the building. Thanks for the tips guys, the people on this website save me a lot of money and give me a lot of new knowledge.
View papadan's profile
papadan
3584 posts in 3272 days
#11 posted 01-05-2014 11:18 PM
If your panel has no main disconnect you can pull the meter to kill all power to the panel and connect your breakers and wiring.
TopamaxSurvivor
#12 posted 01-05-2014 11:47 PM
Jesse, glad you found the main. A multiple occupancy is a much different animal than a single occupancy building. You are still limited to a maximum of six disconnects at the service location.
TopamaxSurvivor
#13 posted 01-05-2014 11:50 PM
Maybe. If it is over 200 amps, it may be a meter connected to current transformers. 320 amp meters have only been out for a few years.
teejk
#14 posted 01-06-2014 01:03 PM
I don’t think you want to pull the meter ever without informing the utility. They tend to freak out when that security lock tag is broken and will assume you have been pirating power.
