Does anyone use WD-40 as a finish?
Forum topic by johnhutchinson posted 01-05-2014 01:08 AM 12197 views 1 time favorited 58 replies Add to Favorites Watch
View johnhutchinson's profile
1243 posts in 1560 days
01-05-2014 01:08 AM
Maybe I should be asking if ANYONE ELSE uses WD-40 as finish, because my brother does. He sprays it on, sands with 400-grit wet/dry paper, and buffs with an old cotton t-shirt. He gets spectacular results and the semi-gloss finish seems to last forever with no discoloration of the wood. Even his work in cherry, which is prone to oxidation, stays bright for years.
-- John - Central Ohio - "too much is never enough"
58 replies so far
View Texcaster's profile
1271 posts in 1604 days
#1 posted 01-05-2014 01:17 AM
I haven’t tried it as a polish but it’s great for knocking out wasp nests!
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Loren's profile
10081 posts in 3578 days
#2 posted 01-05-2014 01:25 AM
Never. It might function like kerosene, which stains
wood. Some old timers were known to use used
motor oil. Many if not most oils will polymerize from
oxidation and thus sort of harden up on the surface
of the wood.
View Monte Pittman's profile
Monte Pittman
28566 posts in 2269 days
#3 posted 01-05-2014 01:28 AM
Guess I have never heard of that before. I will be interested to see the posts.
-- Mother Nature created it, I just assemble it.
View dawsonbob's profile (online now)
2777 posts in 1686 days
#4 posted 01-05-2014 01:35 AM
What Can’t you use WD-40 for, other than on your morning cereal or evening martini? I think Ill grab a piece of scrap tomorrow and give it a try.
-- Mistakes are what pave the road to perfection
#5 posted 01-05-2014 01:51 AM
I read somewhere that it’s been used to refinish hardwood strip flooring.
Wonder if it’s non-slip? :)
What my brother seems to be doing is creating a micro-filler slurry for the wood. I recently saw something on Woodsmith where Don was using a similar technique … but not with WD-40.
13598 posts in 3272 days
#6 posted 01-05-2014 02:00 AM
we used automatic transmission fluid
on the teak at a boat company i worked for in florida
it was cheaper than teak oil
worked ok
View bowedcurly's profile
519 posts in 1659 days
#7 posted 01-05-2014 02:27 AM
gonna try it
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
View BentheViking's profile
1782 posts in 2494 days
#8 posted 01-05-2014 02:38 AM
follow up question. Has anyone used duck tape as a finish?
yeah me either!
-- It's made of wood. Real sturdy.--Chubbs Peterson
#9 posted 01-05-2014 03:17 AM
Okay, go ahead, knock yourself out with a good yuck. :)
He used WD-40 exclusively on the rotary box we published with American Woodworker. We told them what he used, but I don’t think they believed it because they never revealed the “secret”.
View luv2learn's profile
2737 posts in 2233 days
#10 posted 01-05-2014 04:53 AM
I never heard of using WD-40 as a finish but then again I haven’t heard about many things that work as a finish. I guess I will have to give this a go myself :-)
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View lab7654's profile
266 posts in 2177 days
#11 posted 01-05-2014 05:03 AM
How does it smell after it…”cures”? The smell of it gives me a headache whenever I use it. I wonder if it repels water?
-- Tristin King -- When in doubt, sand it.
View doubleDD's profile
7214 posts in 1974 days
#12 posted 01-05-2014 05:34 AM
WE used it as a touch up for trim work that was already finished. Worked great.
View oldnovice's profile
6666 posts in 3298 days
#13 posted 01-05-2014 05:57 AM
I have seen others use it but I have never tried it as I think the smell would never really go away and that would not be very desirable.
View NormG's profile
5900 posts in 2934 days
#14 posted 01-05-2014 06:17 AM
You learn something new daily
-- Norman - I never never make a mistake, I just change the design.
#15 posted 01-05-2014 06:25 AM
For those who have been asking about a smell after it cures, there is none that I can detect.
I think the WD-40 finish must be a wooden clockmaker “secret”. That’s my brother’s primary area of interest. Makes sense, I guess.
showing 1 through 15 of 58 replies
