Anyone using the long HF power bar?
Forum topic by shipwright posted 01-04-2014 02:59 PM 1167 views 0 times favorited 14 replies Add to Favorites Watch
View shipwright's profile
shipwright
7980 posts in 2795 days
01-04-2014 02:59 PM
I just bought one of HF’s three foot long power bars. They seem like a great idea for above a fixed bench. The problem is that the breaker seems weak. For example my router works fine on the outlet that the bar is plugged into but trips the bar. It will power light loads so it’s not shorted.
I think that either
A) this unit has a bad breaker ….. Swap it for another. Or
B) it is a generic problem …..... Return for refund.
Anyone else have the problem?
14 replies so far
View Howie's profile
Howie
2656 posts in 2920 days
#1 posted 01-04-2014 03:04 PM
I have one with no troubles for over a year. Take it back and get another one.
-- Life is good.
View UpstateNYdude's profile
UpstateNYdude
916 posts in 1980 days
#2 posted 01-04-2014 03:05 PM
Probably a cheap breaker, they only use 14 gauge in there also I usually like to stick with 12 gauge for any extension cords, but I would just bring it back and try another possibly buy a couple and test and see if they all have that problem then you’ll know and then bring back the extras or all of them.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View sras's profile
sras
4796 posts in 3126 days
#3 posted 01-04-2014 03:09 PM
A friend of mine is a consistent HF customer. If it has electronics in it, he plans on the possibility of returns until he gets a good one. Often it is not needed, but sometime it might take one or two extra trips…
shipwright
#4 posted 01-04-2014 03:25 PM
Thanks for the quick responses. I suspected it was just a dud.
This is what I love about Lumberjocks.
View Woodwrecker's profile
Woodwrecker
4148 posts in 3572 days
#5 posted 01-04-2014 03:39 PM
Mine has worked well Paul.
Swap it out for a new one.
-- Eric, central Florida / Utor praemia operibus duris
View longgone's profile
longgone
5688 posts in 3305 days
#6 posted 01-04-2014 03:39 PM
I had two of the same outlet strips from HF…one on each side of my workbench. they were relatively inexpensive with the discount coupon…but I did have problems with both of them. On one the breaker kept tripping and on the other one the breaker just failed completely. I did have both of them for well over a year. Instead of replacing them I ended up a metal receptacle box with outlets in them since I never have needed the number of outlets the strip provided.
View Joe Lyddon's profile
Joe Lyddon
10097 posts in 4049 days
#7 posted 01-04-2014 04:57 PM
Paul, if it happens on the replacement, it’s probably your router’s power demand…
How many HP does your router produce?
shipwright
#8 posted 01-04-2014 05:00 PM
Not just the router Joe.
I’ll swap it out and see.
View stefang's profile
stefang
15881 posts in 3331 days
#9 posted 01-04-2014 05:52 PM
Does your router have a soft start Paul?
shipwright
#10 posted 01-04-2014 07:36 PM
No Mike, it’s an old one but again it’s not just the router. I think it’s just a weak breaker.
View Roger's profile
Roger
20928 posts in 2801 days
#11 posted 01-04-2014 10:30 PM
I think those are only 15 amp. But, it still shouldn’t trip if your router is, say, a 12 amp
View Vintagetoni's profile
Vintagetoni
58 posts in 2690 days
#12 posted 01-05-2014 03:53 AM
I have two & found that certain tools trip the breaker even though they draw fewer amps than the specification. For sure the router trips it, even with soft start & so does band saw, which surprised me. But I kept them & find them useful for running bench tools like belt sander, small grinder & corded hand tools. I just had to go more heavy duty & more $$ for the more demanding tools. I find them very handy when I need extension outside my shop…circular saw, sander, lights, grinder & the pancake air compressor doesn’t trip it.
-- toni --- SW WI...working on shop setup....wish I could say diligently. "Time is a healer, a friend & a maker of dreams."
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2502 days
#13 posted 01-05-2014 03:55 AM
I have one. Run my Ridgid band saw, drill press and sander off it with no issues for well over a year now.
RibsBrisket4me
#14 posted 01-05-2014 03:55 AM
In fact I was running my circ saw and router off it today with no issues.
