Forum topic by Jeff_in_LSMO | posted 01-03-2014 04:59 PM | 1064 views | 0 times favorited | 10 replies | ![]() |
Topic tags/keywords: molding I’m finishing up a basement remodel and I want to put up ceiling and baseboard molding. I want to use wood, and I want to stain it dark. I would prefer to keep cost to a minimum. Given those assumptions; 1. What is a good choice of wood? |
10 replies so far
#1 posted 01-03-2014 08:38 PM |
114 views and not one reply? Have I actually found a topic no one is interested in, or even worse, has an opinion on? Am I in forum oblivion? Have I fallen into that bottomless pit, the scientifically unproven albeit mathematically probable black hole of lumberjocks? |
#2 posted 01-03-2014 08:41 PM |
I just think most people buy premade trip these days. |
#3 posted 01-03-2014 09:51 PM |
Going on 5 hours, 125 views, and still nothing. Perhaps if I promised to post a picture of me eating a spider? |
#4 posted 01-03-2014 10:47 PM |
Unless your basement is different from most, I wouldn’t install wood baseboard. Tom Silva, on This Old House, is a fan of PVC molding. And if it’s good enough for Tommy … Check this out—http://www.certainteed.com/products/trim/more-info/PVC-Molding-and-Millwork.aspx -- John - Central Ohio - "too much is never enough" |
#5 posted 01-03-2014 11:01 PM |
Jeff, no need to get all torqued up. :) -- bill@magraphics.us |
#6 posted 01-03-2014 11:06 PM |
I have to agree with John, but if you must use wood, go to a good lumberyard – even then you won’t have very many choices for precut trim. If you are going to buy some other wood than the fir or pine they offer and mill it yourself, to me staining it dark seems like a waste, so you might as well go with the precut stuff, stain it, and apply a cost or two of poly. Just my humble opinion, of course. -- "72.6 per cent of all statistics are made up on the spot." - Steven Wright |
#7 posted 01-04-2014 12:16 AM |
Hey Jeff, just finishing a glass of wine before retiring to the easy chair so if I blur my words, forgive me. The best staining reasonable wood in my opinion is popular. It mills pretty well, easy to sand and takes about any stain you want, of course if you’re going really dark you may need to put more than one coat of stain. As for finish, an oil base varnish/eruothane usually darkens or richens the wood (as I like to say) and water based products when dry don’t really change the appearance of the wood much, other than sheen. I assume that your basement is dry other wise why finish it, but still there is a bit more humidity that settles in the basement so I would use the oil based products. I like satin finish products. Put your stain on and when you get to the varnish part of it take the time to do all sides front, back, top and bottom. I’ve use wood trim in my basements before and never had a bit of trouble doing it the way I just described. Hope this helps. -- Joe |
#8 posted 01-04-2014 12:20 AM |
Hemlock is the usual choice for inexpensive stain grade trim in my area. The grain is somewhere between fir and cherry. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#9 posted 01-04-2014 01:42 AM |
I’m curious ….. why dark stain? Are your existing doors, jams and trim stained dark? White would be easier to match the carpet and wall colors to. More typical in a basement remodel. Better for resale. Do you have carpet and a pad? hold it up 3/4” – (verify fit) and tuck carpet under it. The standard trim choice would be 3 1/4” colonial base or what ever is in the rest of your house. Do you have colonial 2 1/4” casing upstairs? that would be a good choice. This trim comes in clear pine for stain or primed white on all sides and is finger jointed to eliminate knots, if you want to paint it white. I don’t use MDF on my jobs but I hear they’re using it a lot more lately. 2 3/4 to 3 1/4” colonial crown would be a decent choice for the ceiling, you could certainly go smaller but it tends to look weird if you use small stuff like 3/4” cove….better to have nothing. Try to avoid that prefinished foam trim. It really sucks. |
#10 posted 01-04-2014 07:02 AM |
Jeff, John has a good point about using pvc molding for baseboards, I used it when I redid my garage door -- As ever, Gus-the 79 yr young apprentice carpenter |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4901 |
6691 |
28043 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6229 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
