band saw drift
Forum topic by Sawdust2012 posted 01-03-2014 02:02 PM 1331 views 2 times favorited 11 replies Add to Favorites Watch
View Sawdust2012's profile
114 posts in 1647 days
01-03-2014 02:02 PM
I’m fairly new to serious bandsaw work, but the more I use mine, the more I appreciate it, precisely the opposite of the effect with my ex. Is it necessary to reset the drift angle each time the blade is changed? Is it a function of the blade or the saw?
11 replies so far
View JustJoe's profile
1554 posts in 1972 days
#1 posted 01-03-2014 02:05 PM
The Snodgrass video discusses drift.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View JAAune's profile
1780 posts in 2251 days
#2 posted 01-03-2014 05:59 PM
“Drift” is caused by either a bad or dull blade or not setting the blade on the same part of the upper wheel each time it is changed. If a good, sharp blade is installed and it’s set on the middle of the upper wheel each time, it’ll cut the same direction every time.
-- See my work at and
View bigblockyeti's profile
5057 posts in 1655 days
#3 posted 01-03-2014 06:12 PM
Never had issues with drift on my little 9” saw or my 20” saw
View gtbuzz's profile
427 posts in 2376 days
#4 posted 01-03-2014 06:30 PM
Saw this thread title and was immediately going to recommend the video that JustJoe posted. It’s a great video. After following all his tips and unlearning my bad habits, drift has become a thing of the past.
View Surfside's profile
3389 posts in 2108 days
#5 posted 01-03-2014 09:47 PM
Things to check if there’s a blade drift : Blade quality( dull) and blade tension.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View blackcherry's profile
3337 posts in 3757 days
#6 posted 01-03-2014 09:55 PM
If your blades are new replace the tires, go with the urthane tires and say good by to drifting…BC
View Jim Finn's profile
Jim Finn
2641 posts in 2856 days
#7 posted 01-03-2014 10:11 PM
The only time I ever had “drift” while re-sawing was when my blade became dull. I now use a carbide blade, a re-saw fence and get zero drift.
View TerryDowning's profile
1076 posts in 2052 days
#8 posted 01-03-2014 10:53 PM
Great video Thanks Joe.
-- - Terry
View MrRon's profile
4672 posts in 3178 days
#9 posted 01-03-2014 11:52 PM
If the blade is poor quality, you will get drift regardless of how well the bandsaw is aligned. Drift is caused when the teeth set is not the same on both sides of the blade.
View lightcs1776's profile
4190 posts in 1588 days
#10 posted 01-04-2014 01:16 AM
JustJoe, Great link!! I will be revisiting the setup on my Craftsman 113 series 12” band saw tomorrow. I know I will outgrow it, but now I wonder if tuning it as suggested in the video could add a significant number of years with it.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
View Bluepine38's profile
3379 posts in 3019 days
#11 posted 01-04-2014 07:07 AM
I remember reading an old bandsaw manual that said to correct the drift, you should hold a grinding stone
to the side of the blade the drift was towards and this would correct it. That meant you made the good
side of blade as dull as the bad side so it would cut straight. As Joe said watch the Snodgrass video.
