?what type of plane to clean up cherry slab?
« back to Hand Tools forum
Forum topic by toehead posted 01-03-2014 03:32 AM 959 views 0 times favorited 4 replies Add to Favorites Watch
View toehead's profile
toehead
21 posts in 1627 days
01-03-2014 03:32 AM
Topic tags/keywords: plane slab scrub jointerplane question
I’m new to wood working and after a few frames,gates and miter bench I got the itch to work with a slab.its a 20ich x 38’’ x 3ish inch thick slab of cherry.after i bag it in tim-bor(to kill any bugs)for a week i’m gona paint the ends with latex paint and stash it in a empty bedroom with the fan on. I want to use hand tools as much as possiable on this prodject.I know a i need a srcub or a jack plan to start leveling it then a smoother jack.of couarse cash is tight so I’ll hit up garage sells and antique shops and the ole’craigslist….damm i’m long winded. anyway would a jounter plane be good enough to start ,or just make sure its along plane??
View bowedcurly's profile
bowedcurly
519 posts in 1693 days
#1 posted 01-03-2014 03:44 AM
to hog off the high spots a scrub plane will start, but a jack or fore or jointer will work, you have to have a Idea where the high spots are, so you will have to establish a start point, then start hogging
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
View CharlesA's profile
CharlesA
3312 posts in 1761 days
#2 posted 01-03-2014 04:02 AM
Use a Fore or Scrub plane at 45 degree angle to the grain to remove the flat spots, and a jointer plane at 90 degree angle to flatten it. I use Fore and Jointer planes regularly, but I flattened my slab with a router. Here’s a pick of of it:
toehead
#3 posted 01-03-2014 04:04 AM
thanks bowedcurly for the info.looks like a stanley 40 and a 7 will work.from the videos i’ve seen i should work 1st 45 degree angls then with the grain starting from the high side?I’m not sure wich side will be the top,probable the side that comes out the best.
View Don W's profile
Don W
18685 posts in 2531 days
#4 posted 01-03-2014 04:58 PM
A Stanley #40 is a scrub, but if you want to save some money a #5 with a heavy camber will work as well. Use the scrub cross grain at an angle. Then (this step is somewhat optional) use a fore (jack) which will be a #5 with less of a camber. Across grain opposite the scrub lines.
Then a jointer to get it flat. For a slab the size of yours, even a #6 would work well. A #7 would also fit the bill.
Then a smoother. In the direction or the grain, and with the grain to avoid any tear out. A #3, #4 or #4 1/2 will work.
Note if your just starting out, you can grey the lines on what planes to use. You could actually do everything with a #5 and a few extra cutters. Or a #5 and a #4. Paul Sellers has often said you can do everything with a #4. Although I wouldn’t consider it ideal, I am an advocate of getting projects done with the tools I have at hand.
I’m not suggesting either approach, I have a plane tuned for each different step, so its just a mention that its not an absolute requirement.
